anyone know the part # or where i can find new valve seals??
valve seal part #'s??
Standard Valve Stem Oil Seals
Intake: 24507690
Exhaust: 24507691
$3.00 each from GM Parts Direct<b>Mike</b><br /><a href=\"http://www.cardomain.com/id/mcjoslyn\" target=\"_blank\">2001 Camaro</a><br />Light Pewter Metallic Convertible<br />AU0,A31,C60,DG7,F41,GU6,K34,L36,M30,T82,T96,UN0<p ><b>If it can\'t be expressed in figures, it is not science; it is opinion.</b>
ok i have a question,
i ordered these valve seals, and they came in a bundle of 5, and you could only order them in 5's. now dont our engines have 2 valves per cylinder? so wouldnt i need 6 intake and six exhaust? if this is so why would they sell them in fives??later,<br />alan<br />1999 bright red v6<br />3800 series III<br />208\\210 comp cam<br />3000 stall edge tc
they come in packs of 5 because gm wants to be a major pain in the a$$. j/k. really, I dont see how the valve seals would be designed different as far as intake and exhaust. I know on small block chevys, you can use the same seal for either the intake or exhaust valve, so maybe thats the case on the 3.8 as well? I really have no idea, just tryin to offer some help :D1979 Z28 Camaro, 1 of 10,000 Factory 4 speeds. <br />1994 Camaro Sport Coupe, M5<br />Best ET: 15.31@91.5 (25 hp NOS)
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...9 hours ago
