3.1L to 4.3L Swap $150 - FirebirdV6.com/CamaroV6.com Message Board
  • 3.1L to 4.3L Swap $150
    A guy down the road from me has a Vortec 4300 motor from an 89' Silverado with low miles. He swapped for a V8 and now wants to get rid of the V6. The motor is in good shape and has all the parts including exhaust. He said he would take $150 for the whole thing. ;) [img]graemlins/burnout.gif[/img]
    Question is ... Should I? Is the torque / Horsepower alot more than my wittle 3.1L? How much trouble would it be to swap the motors? Is there alot of money involved?
    I plan to rebuild the motor (master rebuild kit $400). Put in a better cam, bore the motor..?
    Any suggestions / comments would be great.
    [*]<b>Car: </b>1991 CHEVY CAMARO RS<br />[*]<b>Engine: </b> 3.1lt (191ci) V6 - MPFI<br />[*]<b>Stereo: </b> Alpine 7995 H/U | Eclipse 21000 EQ | BOSS IQ 3000w Amp | Crossfire AB 400watt Amp | 3 AudioBahn 12\" D/V Subs | Planet Audio 4x6\'s & 6x9\'s
    If it will work then I say go for it!
    <b>Black 1996 3.8L Firebird A4</b><br />--------------------------<br />Custom CAI, Flowmaster Dual Exhaust, 160 Deg Thermo, BMR ShockTower Brace<br />JVC mp3 HU, two 12\" Infinity Kappa Perfects, Infinity 6.5\" components, JBL 600.1 & 80.4 amps <br /><a href=\"http://community.webshots.com/album/479229363CPbPiz\" target=\"_blank\">Pics</a>
      Best of luck trying to get it to fit in ... but it would be killer.
      -Rob
        it will/can fit. Mostly what you need, caint remeber all of it:
        (is it tbi or carb? makes a big difference)
        motor mounts
        engine harness if not included
        ecm
        new tranny w/sbc bellhousing
        new tach
        emissions exempt address
        new catfront exhaust
        new coil springs, maybe
        various tubing/electrical routing
        new afpr , tbi or carb use a LOT less pressure
        relocate motor mounts to appropriate holes in k-mbr
        if e-check exempt, & carb, you got it made, use good 650 non-cc carb, & vaccum advanced non-cc hei distributor. easiest set up for it.
        2013 Ram 1500 Big Horn
        94 comero 3.4
          Actually it has SFI Fuel Injection, not carbed. I was afraid that I would have to replace the tranny. I hope I can find a decent price. I guess the Vortec 4300 used the same tranny as the 350 V8, so the guy im buying the motor from didnt need to swap it out.
          The rest of the swap is cake, pending some cash.
          Thanks ...
            you may wnqat ot convert it to Carb.
            you can get the parts off of earlier blazers.
            I had a 92 GMC Jimmy, was carbed had 190 hp, and like 240 ft. lbd of torque.
            Small block, internals fit the motor pretty well.
            Wonder if you could look into a rebuild kit, for a cyclone to Typhoon? Maybe even lead to forced induction in the future. Might not even cost all that more.
            But for the swap, I would guess it owuld be the same as a small block conversion if oyu were going carb.
              Just for the sake of asking a question ...? Why would I want to convert to carb? I thought Fuel Injection was better? I could be wrong.
              I would like some more information about those rebuild kits you were talking about. If Im going to spend the money to rebuild the motor, I may as well do it right the first time!
              Thanks ...
                <blockquote>quote:</font><hr>Originally posted by DigitalBee:
                Thanks ...
                <hr></blockquote>
                I am pretty sure it is TBI (throttle body injection) not SFI. SFI did not come to the chevy trucks untill 96, they did not offer it in 89, unless that is a newer motor.
                2004 Dodge Dakota 3.7 litres of raw power!!<br />Nothing but a 6!<br />Do you know for sure? John 3:18
                  toast ic correct, sfi didn't come into 96. I have a 95 blazer w/cpi. I think 94-95 were the only two yrs made w/it, but could be wrong. carb would be easiest because there is a sheesh load less wiring to done.
                  94 comero 3.4
                    My 91 gmc 4.3 jimmy is efi fuel injected
                    Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
                      is it TBI?
                      94 comero 3.4
                        $150 for the engine seems like a good deal but if you look at it the way I do you have to buy a transmission and while i'm not sure how much money specifically it will be im guessing it can be anywhere from $500 + for a decent one and with all the issues you'll have with getting that thing to sit right or custom mounts it doesn't seem like it would be worth it in the long run. I can see where your going when you want to convert to a different engine over the 3.1L. A friend has a Vortec 4.3L SFI in his 96 S10 SS, I think he has a gutted cat back 3in exhaust with some K&N air filter on it and 3.42s. He went up against john(toast) who has a 3.8L with just the dynomax muffler on it at the time and 3.42s. John must of killed him but 2 and a half car lengths. The engine your looking at is probably TBI and is made more for torque I think it will be a dog and a waste of time trying to put it in. You probably wouldn't see a whole lot of gain man. I see a lot of guys around swapping out there 3.8Ls for lt1s or ls1s. If I were you I might jump on one of the deals on ebay i always see complete 3.8L engines with trannys for like $500. They're great engines and i'm sure you could get it in there some how. Or why not just go all out with a 350???
