24 or 26lb injectors? - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    so i got some stock 24# lt1 injectors off a local guy here for cheap..installed them today, went to plug the connector on & the #(*#%@$@$ connector on the injecotr is different!!!
    so now i'm looking for a lt1 harness...should be picking one up tonight so i can splice in the correct connectors :(
    --matt
    • #17
      got a harness of an early 90's v6 buick..cut the old ones off, spliced in the new connectors and the car runs just fine. still need to autotap tho to check out the new pulsewidths.
      --matt
      • #18
        thats good to hear..
        let us know the results..
        • #19
          http://www3.sympatico.ca/2002camaro/docs/run1.csv
          http://www3.sympatico.ca/2002camaro/docs/run2.csv
          so i'm in the 13-17ms range now, in the 845-950 o2 mv range. so is that good?? or still too rich/lean?
          --matt
          • #20
            Hey, just a thought, how old is your catalytic converter?
            1997 Dodge Viper GTS
            • #21
              it's about a year old now..15000 miles or so i think :|
              --matt
