Will these heads work on the L32 3.4 and are there any performance gains
gmpartsdirect.com p/n 25500030
description : The aluminum Stage II cylinder head is a light alloy head with rectangular intake ports and square exhaust ports. 100 valve angles, unfinished seats for 2.02" diameter intake valves and 1.60" exhaust valves are installed. This uses 3/4" tapered seat spark plugs. Comes without valve guides installed. Technical Notes: Stage II aluminum heads use the six bolt pattern found on Stage II blocks which require longer studs and are available from aftermarket sources. Requires rocker cover P/N 25500122, rocker cover gasket P/N 25500175, intake gasket P/N 25500173, exhaust gasket P/N 25500174, and intake P/N 25500029 or P/N 25500170
