hey i had this code on my fails since clear and it has something to do with the way my car has been running( hesitating horribly, shuddering/vibrating) has anyone else had this problem. the code says engine misfire
dtc 0300b
I assume you mean P0300, since there is no such thing as B0300. B codes relate to the air bag system, P codes are for the PCM.
P0300 is the generic code for a multiple misfire. The PCM is unable to determine which cylinder is misfiring. Could be 1 cylinder or could be a few.
Going by the symptoms alone, you've got a bad misfire. The DTC is just stating the obvious.Matt
1998 Mystic Teal Camaro M5
well i reset the codes today and it hasnt come back yet. my auto teacher says it could be alot of things..including injectors, or my ign. components. so i dont have any idea now. is there anyone that has had this problem?The confusion surrounds me <br />change is imminent<br />if I were they<br />we could be great
Thousands of people have had a car that misfires. Start with the obvious: plugs + wires. Then check fuel filter, injectors, coils, ICM, fuel pump, etc.Matt
Originally posted by 98Camaro3.8:
Thousands of people have had a car that misfires. Start with the obvious: plugs + wires. Then check fuel filter, injectors, coils, ICM, fuel pump, etc.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
plugs are brand new, wires prolly have 90k on em. fuel filter is brand new, coils and all that are being replaced monday with msd, so i dunno. how much mods would require me to get a bigger fuel pump?The confusion surrounds me <br />change is imminent<br />if I were they<br />we could be great
Originally posted by Yaba3800:
how much mods would require me to get a bigger fuel pump?Matt
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.3 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
