First Time at the DYNO........... - FirebirdV6.com/CamaroV6.com Message Board
  • First Time at the DYNO...........
    With the constant tweaking I am doing with Air/Fuel Ratio's and on a minimal budget I took my car to get dynoed for the first time....
    August 8th 2003 (DYNOJET)
    Temp 86 Degrees
    Humidity 82%
    My car is at stock weight
    61000 miles with factory tune up parts still on car
    I am still running stock manifolds, Running through the exhaust, Stock Convertor, and 3.73 Gears which is a 4 to 5 RWHP loss but quicker acceleration....
    178.4 RWHP 214.2 RWTQ SAE Corrected
    Air/Fuel Ratio a WOT was pretty much 13.0 across the Board. Doesnt get much better than that...
    New track munbers to come after F-Body Event on the 16th....
    Eric
    Eric
    2005 Mustang 4.0
    1996 Camaro Conv
    2000 Ford Excursion
    "Darkness Falls"
    gears shuld not effect your hp readings..
      gears affect tq, which slightly affects hp.
        Gears do affect torque but a good dyno should be able to compensate for that.
        1996 Silver Camaro, Y87, M5, cammed..<br />N/A Best Time: 14.012 @ 98.59<br />195 rwhp / 233 ft-lbs b/f heads/cam<br />Check out my site <a href=\"http://silver3800.cz28.com/\" target=\"_blank\">http://silver3800.cz28.com/</a>
          <blockquote>quote:</font><hr>Originally posted by AllTheGoodNamesAreGone:
          gears shuld not effect your hp readings..<hr></blockquote>
          The numerically higher gear 3:73 or 4:10 will cause u to drop in hp on the dyno. my gear jump was from 3.08 to 3.73....Also a big stall will eat up some HP on the dyno. Here is where dyno #'s are useless. After u add whatever gears and TC U WILL go faster than the car was before the gear & or TC swap. It will just show a lesser # on paper for the dyno.
          Eric
          Eric
          2005 Mustang 4.0
          1996 Camaro Conv
          2000 Ford Excursion
          "Darkness Falls"
