that cold ait things a good idea....I just got it suckin hot air fomr engine bay with a filter over it....well I got something to do tonight ;)
EGR delete
yeah I just installed my headers a few weeks ago and have been sucking hot air for a while, but the question is will this give sufficient flow through the egr system to keep the SES light off?3.42 gears w/ LSD,<br />Headers, Cat delete, Loudmouth,<br />SLP intake, K&N, Whisper Lid, <br />EGR delete
Red, crap, I've had that dissconnected for years now [img]tongue.gif[/img]
I was thinking of removing that cylindrical thing for more weight reduction and freeing up a cluttered engine bay :0
Thanks for the info/ explanationRace car - gone but not forgotten - 1997 firebird V6
Mine is gone there isnt a hint of EGR there. just need to put a plate over the intake side and i stuck a big but short bolt in it and seal it with ultra copper rtv<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
<blockquote>quote:</font><hr>Originally posted by Quijeeboe:
yeah I just installed my headers a few weeks ago and have been sucking hot air for a while, but the question is will this give sufficient flow through the egr system to keep the SES light off?<hr></blockquote>
mine does ;)
05' CTS-V
00' Camaro - SOLD :(
Thanks, Merlin. Appreciate your observation.
John2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
Just for clarification the 18K Ohm resistor I gave Red was to keep his 160 stat from throwing a code and killing the gauge [img]smile.gif[/img]
Im sure it does increase timing advance too though, but who really knows? I just don't like my coolant gauge dying [img]smile.gif[/img]
Something else you might like knowing is the EGR is there to reduce engine cyl temps, thereby reducing the tendancy to ping at idle or partial throttle on 87 octane. With 9.5:1 compression, the tendancy to ping goes up a lot if you remove the EGR. At WOT, the EGR shuts, so IMO it makes no sense to remove it.
[ August 24, 2003: Message edited by: Dominic ]</p>2002 5-spd NBM Camaro
Details: www.1lev6.com
i understand what your saying about cyl. temps and pinging, but imo i think that anyone wanting to do this mod would be running a higher octane, like myself... and i was unaware that the EGR shuts at WOT, thats interesting...
merlin2002 Firebird<br />2003 Yamaha YZF 600R
<blockquote>quote:</font><hr>Originally posted by Dominic:
yep partial throttle only, so it doesnt bother me.<hr></blockquote>
do you floor it at every light?....not being an a$$hole but a little more power with less throttle is nice
05' CTS-V
Im not sure if this would apply or not, im not clear what our electrical connector looks like (i am going ot look later to see.) but this could prove useful for those who want to !EGR [img]smile.gif[/img]
http://www.mohdparts.com/egr_mods/defeat/index.html2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
its an interesting idea, but our egr connector doesn't look like that, there are 5 wires comin out of it? so which ones need to be hooked up with the resistor? i think it can be done by trial and error, and an autotap is probably needed as well...
and has anyone else messed with their egr, i ordered the block off plate and plan on routing the egr tube to the airbox...
Our setup its definatly differnt than theirs, however you have to look at this factor.
Our connect is going to supply a ground, and a power wire, so you can elimnate two right off the top with a simple multi-meter. Just identify those two wires. Then their is probably another wire that goes over to the throttle body so that it knows when your not @ WOT, so you could posibly eliminate 1 more wire, leaving only two... its likely that those two wires would be the ones that would need the resistor...2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
does anyone have any dyno info on the egr delete? or track times to see if it helps at all? i dont think it would help because it would just make your engine temps higher? plus the egr only comes on when you are cruising? or at least thats the way that i understand it. thankswhite 1996 camaro 3800: flowmaster American thunder cat back. hypertech 160* stat, and manual fan switch
