EGR delete - FirebirdV6.com/CamaroV6.com Message Board
EGR delete
  • #31
    <blockquote>quote:</font><hr>Originally posted by nikon:
    do you floor it at every light?....not being an a$$hole but a little more power with less throttle is nice
    <hr></blockquote>
    more power? What if it pings and pulls timing? that would make less power [img]smile.gif[/img]
    If I need more power at partial throttle, I'll give it more throttle. When I need more and hit WOT, EGR shuts off, sounds fine to me. Keeps me from pinging too. Doesn't bother me much at all, one of the few pollution controls that works ok. If I end up getting a cam with lots of overlap though, I will remove it.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
    • #32
      The EGR isn't there to control pinging, although it's purpose is to cool combustion temperatures, but to keep Nitrous of Oxides (NOx) down in the exhaust.
      As to how to avoid the SES by blocking/bypassing the EGR, the service manual is very helpful here, I just wish I would have read it before.
      According to the service manual, say the exhaust stays balanced enough that the PCM never needs to add EGR gasses to the mixture, the PCM will still open the EGR valve at regular intervals, to verify that it's working. The PCM verifies that the EGR valve is working by looking for an increase in manifold pressure (drop in manifold vacuum).
      So, if you remove the EGR from the exhaust manifold, and hook it up somewhere that it can pull air (the air intake), then there should still be slight change in manifold vacuum, apparently enough to make the PCM happy (did the software geniuses at GM actually give us a break for a change?). A place that could puts some pressure behind the air might be better, so perhaps some type of a pump, a small electric one maybe, using a PCV breather filter to draw air through?
      Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
      • #33
        <blockquote>quote:</font><hr>Originally posted by Guardsman:
        The PCM verifies that the EGR valve is working by looking for an increase in manifold pressure (drop in manifold vacuum). <hr></blockquote>
        What about my turbo? :-D
        • #34
          You guys might want to get in on this beta test [img]smile.gif[/img] http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
          Also, I'll be honest I have not read the ENTIRE thread so i'm not sure if this has been brought up (Probably has) what I did for a long time was remove the tubing from the exhaust and put a small K&N filter on the end of the EGR inlet and blocked off the hole in the header. Worked like a champ.
          [ September 01, 2003: Message edited by: GTPprix ]</p>
          Chris White<br />1989 Turbo Trans Am #70<br />2004 GTO - Procharged<br />2005 G6<br />2005 Equinox LT AWD
          • #35
            I was doing a search to fix my EGR leak and noticed this. I was wondering if anything else has come about for this? Any new idea's, problems, etc... (I am talking mostly about the rerouting of the egr tube)
            98 Silver Camaro V6<br />15.238 @91.74 w/ 2.288 60\'<br />Mods: K&N, FTRA, Pacesetter Headers, Spec 3 Clutch, 160 Thermo, TSP Rumbler, 3\" Catco, Whisper Lid, 3.42\'s w/LSD, Aluminum DS, Man Fan Switch<br /><br /> <a href=\"http://www.cardomain
            • #36
              Ok... for the last time. The egr ONLY opens at cruising speeds. You will see no difference at WOT, or idle. It makes absolutely NO sense to consider this a performance mod of any kind.
              • #37
                Those of us with HP Tuners software can delete the EGR function in the PCM can't we? Might be a thing to do if you send your PCM into TSP for some computer work or if you have the VCM Suite.
                2001 Pewder Firebird V6 A4 <br />Custom Turbo Kit Details On Site<br /> <a href=\"http://www.cardomain.com/id/njp98\" target=\"_blank\">http://www.cardomain.com/id/njp98</a> <br />Best 1/4 time NA - 15.224 seconds @ 87.55 MPH
                • #38
                  I wasnt talking about performance gains. Sorry I didnt specify. I have a EGR leak that I have tried fixing a couple times without good results.
                  That is the only reason I was asking.
                  • #39
                    Actually, you can see a perf gain, it is in weight reduction [img]tongue.gif[/img]
                    It is done now on my bird
                    • #40
                      Originally posted by 12secondv6:
                      </font><blockquote>quote:</font><hr />Originally posted by ReodDai:
                      Actually, you can see a perf gain, it is in weight reduction [img]tongue.gif[/img] Hi, I'm a smartass
                      </font>[/QUOTE]Ok ok. That and maybe a slight reduction in intake temperature's while street racing. However for drag (other then weight) you won't see a difference.
                      • #41
                        I know a lot about the EGR, not because I been trying to delete it, but rather fix it.
                        Here is a diagram from a service manual,,now we can
                        refer to this. Teal can you make it an image rather than a link?
                        1- Pipe from exhuast manifold and mounting point for valve.
                        8- EGR Gasket
                        9- EGR Valve
                        11- Sensor Plug
                        If you disconnect the EGR Valve, you will probably set P1404.
                        Here is the info about what electrical circumstances sets the SES DTC code.
                        Circuit Description
                        The PCM monitors the EGR valve pintle position input to ensure that the valve responds properly to commands from the PCM. When the ignition switch is turned ON, the PCM learns the EGR closed valve pintle position. The PCM compares the learned EGR closed valve pintle position to the Actual EGR position when the EGR valve is commanded closed. If the Actual EGR position indicates that the EGR valve is still open when the PCM is commanding the EGR valve closed, DTC P1404 will set.
                        Conditions for Running the DTC
                        System voltage is above or equal to 10 volts.
                        Conditions for Setting the DTC
                        * EGR Feedback is 0.2 volt greater than the EGR Closed Valve Pintle Position when the Desired EGR Position is commanded to 0%
                        * The above condition is present for around 20 seconds.
                        I have a diagram of the EGR Electrical Schematics, if anyone is interested.
                        [ July 09, 2004, 12:39 AM: Message edited by: PewterBird ]
                        Cardomain
                        • #42
                          Another reason to remove an EGR is when putting in a turbo system for forward swept headers. I removed mine to free up some space in the engine compartment, it doesn't seem like much but it really helped to open it up.
                          • #43
                            posted by 12sec:
                            I was thinking of removing that cylindrical thing for more weight reduction and freeing up a cluttered engine bay :0
                            Yeah, cuz there's waaaaay too much in there!!! [img]graemlins/rofl.gif[/img] :D
                            2004 CE Corvette 10.86@132mph
                            2011 Cadillac CTS-V
                            2006 Mitsubishi Eclipse GS
                            • #44
                              I have a new EGR and EGR tube if you need another..
                              Jeff ..
                              1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
                              2002 WS6 T/A.. Bolt ins..448rwhp
                              2009 G8 GT.. Vararam intake, GXP axleback
                              1998 Corvette.. Vararam intake, Ti axleback
                              http://www.fquick.com/slow-v6
                              • #45
                                The tube and egr are fine. I just can't get that white gasket tightened down enough to keep it from leaking. I have tried taking it off and resetting it, bending it this way and that way... Just won't stay tight.
