Im putting a powerdyne unit on my 98 v6 firebird and ill like to put some good fuel injetor can anyone tell how to chosse the right ones and were can i purchase them
Fuel Injectors
There are some formulas and calculators and things in the tech database to help you size the injectors based on your anticipated hp.
I bought accel 24lb injectors from summitracing. So far they work great. I have to use a maft to adjust the maf reading to keep from running too rich at idle though.
accel has a site that lists the part numbers for the different flow ratings. summit uses basically the same part number. If you want a 6 pack, substitute a 6 for the 8 in the 8-pack part number.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
Yeah, best ones are stock.
I ran accel 24 pound injectors with a computer that was not reprogrammed for them and ran rich off the line and lean top end and then grenaded my engine on the bottle 1 month later from installation.
Stock ones work fine.Race car - gone but not forgotten - 1997 firebird V6
