machine shop cost - FirebirdV6.com/CamaroV6.com Message Board
machine shop cost
  • machine shop cost
    how much would it cost to have all new bering put in. cam, rod and main bearings. Have the block and heads pressure tested for crackes and the clylinders honed and 1 more thing a vavle job please if you know the what this would cost with avaerage labor and everything let me know thanks
    1999 Firebird 3.8 Chamelon<br /><br />MagnaFlow Catback<br /><br />Devon
    these are the prices I got from my local machine shop.
    Clean Block: $45
    Cam Bearings: $25
    Bore cyl: $20 each
    Press Pistons: $5 each
    Balance: $160
    Recondition Rods: $15 each
    Grind Crank $135
    Line Bore: $175
    Shane
    00 Pewter Y87 Camaro-SS Hood/Chrome rims, Black Halos, Clear corners, Pacesetters, V8 K&N FIPK, 3\" B&B TriFlow, HPP3, MSD Coils, Taylor wires, Transgo stage II, Edge 3000 Stall, 180* thermo, SLP Bowtie Grill<br /><a href=\"http://www.cardomain.com/memberpage/468763/1/\" target=\"_blank\">Carro</a>
      i think knwo all i need is the am bearing main bearings rod bearings crank ground down and a cyclinder bored does anyone knwo if u bore 1 do u have to bore all the toher ones and also how do u know if your rods need to be recondtiond thanks alout man knwo i knwo what prices to look for
        First off Ive been told not to touch the stock crank. Second you dont have to do every bore. If only one bore is messed up(small scuffing) than you could just fix that one with a hone, but I would think that if you have it pulled apart that far, why not.
        Once you touch the bore's surface you need new rings, if the problem is deeper than a hone, it needs to be bored out, then you need new pistons, and to my knowledge you cant buy just one.
        To me it doesnt make sense to just do one unless on an XTREME budget.
        Reconditioning rods usually consist of checking for cracks, resizing the bearing bores and balancing them.
        Third and final comment..PROOF READ...PROOF READ...PROOF READ
        Shane
          If you bore the cyl's you will need bigger pistons too. They should be good with just a hone unless there tore up.
          A good Ballancing job is all ways good, one of the best thing you can get for your money all most more than any thing else.
          A main reline is not cheap but if you mixed up the main caps or the old main bearing show ware the could have been caused by missalinement then do it.
          \'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
            here im sorry for so poor grammar im not great a typing. So far i well need
            1.Main bearings 75$
            2.Cam bearings ?
            3. Rod bearings 25$ i think
            4. hone cylinder it really just has some water marks like a liittle trace of rust were the head gasket might have been leaking either the head or gasket ?????
            5 im not great with cranks but there are bearings on them to right, only one is scuffed up so thats why i thought i would have to get it ground down but if i can just by new bearings for the crank that would be great ????
            6. Need block and head tested for cracks
            7. New piston rings 100$ GM
            i plan on doing as much as work as i can so ill be putting the block togther so if anyone knows if i can do all this for trying under 800$ for parts&labor
            [ June 22, 2004, 01:10 AM: Message edited by: therock ]
              anyone know if it can be done
                For $800?
                Just set aside $700 for machine work alone, because you never know they might find bent valves or your deck or heads might need to be milled
                The crank bearing are part of the block (they dont spin) and the rod bearing are part of the rod because they don't move with the crank, they should stay put as if they were part of the rod.
                  no its only 80 to rehone
