I'm posting this in Advanced because I sat down and paged through my fluid dynamics texdtbooks for a few hours, so it darn well is advanced :)
I was spec'ing out my new exhaust, and there's lots of talk of how bigger pipes will reduce backpressure and velocity the bigger you go. I decided to plug the numbers and find out. Calculations are for turbulent flow in a drawn (almost smooth) metal pipe.
Flow rate is based on an engine producing 220hp. Flow rate in CFM is 2.2 times hp, I checked this rule of thumb with some chemistry and it's pretty good. Much nicer than figuring fuel flow rates for a certain hp and calculating exhaust flow rate, adjusted for pressure and temperature.
Here's the numbers. The numbers are for the pipe only (no cat/muffler), and have adjustments made for effects of bends on flow.
Some notes:
Both velocity and backpressure scale linearly with flow rate and length. This means that no matter what horspower I put in, or what length and bends of pipe I assumed, the ratios of velocity and backpressure remain constant - 3" pipe will always have about 1/2 the velocity and 1/4 the backpressure of the 2.25" pipe.
So, how much backpressure is needed? I'm not sure. Dynomax calculates their "Loss Free Airflow Capacity" with a 20.3" drop for the just the muffler. If we assume the cat to be about the same drop, moving from 2.25" pipe to 3" pipe reduces the total system backpressure by about a third. I think it's fair to say that highflow cat, 3" pipe, and aftermarket muffler would cut backpressure by at least half from stock.
Any thoughts? I'm trying to rationalize an equation that tries to balance out the effects of the reduced backpressure against the lower velocity, which would both affect the scavenging of exhaust from the cylinders (which affects power).
-Jeff
Some notes:
-Jeff
