97 GT vs 98 3.8 - FirebirdV6.com/CamaroV6.com Message Board
97 GT vs 98 3.8
This topic is closed.
  • 97 GT vs 98 3.8
    i have a race setup soon..
    What do i need to suceed..\\\\
    Competitions car.. 97 Mustang GT 5 speed
    full weight with 2 12 in subs in trunk.
    Mods: LT headers, h-pipe, flowmasters, 4.10 gears, PI Heads and cams. and stree tires.
    MY car. 98 camaro 3.8 , Auto.
    Weight reduction,
    spare tire and jack, swaybar(front), front and rear seats,..
    I have no t-tops and no power windows.
    Mods.
    Fast toys ram-air, holley filter,
    bullet muffler in place of cat
    160* t-stat
    I know i wont win now,
    But befor i plac on running him i plan of 3.73 gears and zexel LSD, cutout after the bullet
    And MT drag radials///
    Do i Have a chance...
    If not what do i need...
    I would be willing to do rockers or a torque convertor if reasonalbe price?? Please help
    David
    98 camaro 3800 A4<br />4.10\'s, LSD, FTRA.<br /><br />00 Z28 Cam Only. <br />11.85 @ 116 1.56 60ft
    i do have a NX wet kit i might run a 50 shot if really need be???
      I'd definatly run the 50 shot because with full exhaust, 4.10s and PI heads and cams that stang isn't the slow *** high 15, low 16 second car it was stock. I wouldn't be surprised if he ran a 13 (depending on the cams he has).
      \'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
        pi heads and cams are stock cams and heads out of 98- newer mustangs so nothing special...
          ok so longtube headers and exhaust along with 4.10s will get it to 13s then. (my friend dustin ran 13.7s all day with his 02 GT with just exhaust)
            but 02 Gts are nice motors the 96-98 2v's are the worst motor ford ever produced.. its a low 14 second car. MAYBEEEEEEEEEEE high 13's with the 4.10's. get your gears. and save the money and buy a nice N20 kit. spray a 100 shot and own his booty. your basically going to need about 60-70 HP or at least 1 second faster. but on the street its HP/weight that owns. either dump alot of weight or gain some HP. cheapest fastest easiest way to to spray and pray.
            my freinds 96 GT with shift kit. full aftermarket ignition . flowmasters . off road H-pipe , cold air couldnt get out of the 15's lol.. freinds 97 saleen vert base model ran 16's on SPRAY.. have no fear. thos engines are TRASH.
            you can either go the easy way and spend 500$ on a nitrous kit and win . or dump ALOT more than that into mods that might effect driveability. including FULL exhaust,gears, shift kits, and a good tune. if not more .
            just something to think about.
            1996 Dark Green V-6 auto. few mods.<br />previous rides:<br />1989 turbo 5 speed dodge caravan (18 PSI, 3\" exhuast,intercooled blah blah)<br />1989 Mustang GT (11.72 @118 many many mods, blown engine a.t.m. :-( )
              The motors are trash because of ****ty heads and cams but he put the good heads and cams in there from the newer motors thus no longer making it trash.
                true true. 96-98 GT =215 HP
                99-03 i think? = 260 hp
                still i have never seen a 96-98 that impressed me
                i think MM&FF did the PI conversion on a car with an exhuast and picked up 26 RWHP...
                  yeah he has no quarter mile times.. but has lost to cars that have gone 14.3's.. I raced him
                  from a 15mph roll to about 60mph and he had about 1 car on me if that.. but he did not have the longtubes or gears...
                  Then again i had nothing at all .. full weight and 3.08 gears...
                  i do have a NX EFI wet kit i will hook up and im sure i can get him.., but what convertor should i get to go along with the 3.73 gears and n2o..
                  I want the motor to be strong N/A as well???
                    gears. will help alot.. nitrous will let you pwnt him sickly.. and a good exhuast will help you make more power on nitrous..
                    strong yes. im just saying.. if you just want to beat him. dont do to many mods that might effect drivability when you can always just spray someone to prove your point ;)
                      if hes got 4.10 gears im hoping that he has some good tires to back his *** up when he nails it out of the hole. Cuz stock GTs already have problem getting traction on the street.
                      but with 3.08 gear/ open rear end, you wont have a chance off the line unless he just sits there and smokes them. Which eventually he'll catch up anyways. So unless you do a few more things i dont think you can win.
                      Heres a vid of me racing a 99-03 GT a couple months ago.
                      http://meissenation.com/tim/3rdGenandGT.wmv
                      99\' W68 Firebird<br />SLP Ram air kit,Whisper Air Lid, k&n, 8mm Taylor Wires, Bridgestone Potenzas RE950, BMR Red LCAs, Pacesetter Headers and 3\"in catalytic converter with 2.75\" Flowmaster Cat-back<br /><br /> <a href=\"http://www.cardomain.com/memberpage/501008\" target=\"_blank\">http://www.cardomain.com/memberpage/501008</a>
