Well to start, the car is a 2001 Automatic with right about 96K miles on it.
I have a Comp cam 210/220/.512/.512 @115. Magnaflow 3" system w/cutout. 3" ungutted cat, stock tubular manifolds. 3.42 gears, Lid, Taylor wires, NGK Tr55 plugs.
Heres the deal. Last March-may 2004 when i was running the car N/A after the cam swap it was consistently in the 14.6-14.70 range with 2.1 60's on a decent day. Not optimum weather at all. Over the summer june-september was my nitrous kick. Running 13.30 and still like 14.65 on motor. Well a year went by and the car never made it back to the track, and over the winter nothing was added to the car but a set of pushrods and a good cleaning out of the heads, no porting, just removed as much carbon deposits as possible. Raced the car again this year and it was running worse than stock times (15.0). The best i could get was a 15.2@87. 60's were 2.2's. I got a code on the way back that the O2 was bad, so i replaced both front sensors, and also did the !knock sensor mod. Went back and still running the same. Was able to squeeze a 15.0@88 with 2.25 60'. I am NOT spinning, launching the car at around 2K. I am puzzled, the weather wasnt great at all, mid 90s with humidity, but i wouldnt think its enough to take almost .7 seconds off the time.
So now i am at school, car is home in the garage, and I am tryin to make a list of things to check, change or upgrade when i return for breaks.
I want to do a compression check, thinking maybe the nitrous caused the rings to go out a bit.. or maybe a bad valve seal.
Also thinking maybe the cat is clogged... car runs rich, i know that, but it is as rich as it was when i was running 14.60s so...
Transmission slipping.... 96K on the car 76K on the tranny, and i have not been nice to it at all
Maybe i just need better weather..... I am at a loss... if anyone has any imput to what I should look into would be greatly appreciated. I dont want to tear too much into it, but if need be I will at least get the heads off and send them away for a valve job and a port.... but now I am just mainly concerned on getting it back to previous times, not go any faster than before... just incase thers somthing serious that would be worsened by more gofast parts.
Sorry for the long post, but gots to get all that info in there.
