will this cam work ??? - FirebirdV6.com/CamaroV6.com Message Board
  • will this cam work ???
    degree dration @ .050 228int. 238exh.
    degrees advertised 290int 300exh
    degree lob seperation 112
    open/close @ .050 camlift
    int exh
    7 4
    56 2
    lash hot .022int .022exh
    grosslift .460int .480exh
    help
    1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
    never mind i have to pass emissions and i can't with this cam [img]graemlins/thumbsdown.gif[/img] [img]graemlins/thumbsdown.gif[/img] [img]graemlins/crybaby.gif[/img]
      Yea and that cam is WAYYY to big..
      You'd be making peak power well past your rev limiter.
        even though the peak hp will be past my rev limiter wont it still make good hp i was told if i run a msd i could burn up the extra fuel and pass emissions??
        any opinions
          your bottem end torque would be nonexistant.
          Just because you make peak power higher in the RPM band doesn't mean your entire RPM band has more power. The lower RPM's will actually lose more power.
          You'd be better off with a cam that peaks around 5200-5500 is your rev limiter is 6000.
