93V6, when your oil looks like chocolate milk, that is because coolant is mixing in with the oil (opposite of what is happening in this case) and that means usually indicates a ed block...where as a ed head (or head gaskets would cause the reverse - oil in the coolant)
<b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
Coolant is very abrassive. When coolant gets inbetween the bearings it wears them down FAST. There is NO protection.
If you are lucky enough to catch it quickly, the wear will be minimal, but there will still be excess wear. It may last a few days/months, if you are LUCKY years... its a gamble.
Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
<blockquote>quote:</font><hr>Originally posted by Magnus: its a gamble.<hr></blockquote>"You got to know when to fold them...know when to walk away...and know when to run. You better count your money...."
[img]graemlins/fluffy.gif[/img]
Well i got my car back they changed the ignition coil , spark plugs, and wires and it seems to be running fine but who knows i havent run it for a long period of time . i think im gonna have another mechanic check it out this tues.
- Why tiptoe through life to arrive safely at death -
why dont you do a simple compression test? that will tell you what is wrong and if the oil is in the coolant wouldnt the coolant be in the combustion chamber and be blowing smoke out the tail pipe? oil in the coolant and not in the combustion chamber sounds like it could be a cracked block. I dont know I am just thinking. hope you figure it out. good luck.
white 1996 camaro 3800: flowmaster American thunder cat back. hypertech 160* stat, and manual fan switch
theres also no smoke coming out the tailpipe it sounds like it might be taht front seal but not sue yet the mechanic is suppsosed to check it out tues ill let u know how it goes
It is possible to have trans fluid IN the antifreeze, since the trans cooler and radiator are all 1 unit. The trans cooler could be leaking internally. Had to change a radiator in an S-10 not too long ago that had that problem.
Thats just something else to look at if they said that theyve done tests and neither have pointed to a headgasket. It could have a cracked block but the compression test would probably tell you that. Its pretty hard to tell what is in the Antifreeze since trans fluid and oil would look pretty much the same.
I also do not see how the front seal being bad would allow oil into the antifreeze. The front seal would be the seal thats around the crank holding IN oil right?Sounds to me like youve got a leaky seal and they just wanna jack you out of some money to fix it.
Do a compression test on the radiator if youre losing pressure youve got a leak. Not necasarily a leak to the outside but it could have an internal leak.
well i ll see what the new mechanic saysand the seal they were talkign bout isnt called he front seal but it can have oil in the antifreeze im pretty sure
well the guysat the marathon werhe i origanly took it are dumb god htey replaced the part that was bad with a defective part they missd oil in the radiatior and all the intake manifold needs to be replaced bucasue the gaskets are bad the onlyg ood hting is that the marathon is replacing the part for free adn they told me i need a whole newe power sterring pmp and htis other place says i jsut needanew hose ahh i hate them
I wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....
