fuel pressure guage.... - FirebirdV6.com/CamaroV6.com Message Board
  • fuel pressure guage....
    would this one work?
    http://store.summitracing.com/partde...art=ATM%2D5412
    96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
    Sure, if your going to mount it outside of the cockpit, like under the hood or on the wiper cowling.
    You cannot have a mechanical gauge in the car because that requires the fuel to be hooked directly to it. You will need to get an isolator for this gauge if you intend to have it mounted inside the cockpit, or get an electrical gauge(that uses a sending unit).
    2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
      yea, what sucks is that you need to use an electrical one in the cockpit cause hes right, you cant have fuel run into the car. and the electrical ones are a $$$$$$$$$$$$$.
      otherwise, hook it up outside of the car, in the engine bay.
        Soon i will be needing one...This cost alot and are kinda hard to find...
        New:04 GMC Sierra 1500 RCLB 4x4 5.3 GU80 3.73\'s.<br />Truck pics<br />Mods<br />Go fast: Panel K&N filter and soon SS truck catback.<br />Appearance: Stull Billet grill,Weston Chrome step tubes,Rhino Chrome hitch step,ARE painted fiberglass cover,Silver star lighting.
          I found mine used Ultra-Lite Autometer 2 1/16" 1-100psi Electric Fuel pressure gauge with sending unit for like $65 shipped- the deals are out there you just need to search.
          Try like dsmtrader.com
            <blockquote>quote:</font><hr>Originally posted by Ian:
            <hr></blockquote>
            k, if you have no leaks, which you shouldn't anyway, who cares if you have a mechanical fuel gage in the cockpit? will the tracks in the usa not allow that?
            --matt
              Its a matter of fumes anyway. Just trust everyone on this and mount the mechanicals outside, electrics inside. Big issue is that stuff like this fails -- hot oil spills on your leg, or maybe fuel spills in your cockpit and ignites on your cigarette.
                These elec fuel pressure gauge usually goes pretty cheap.
                http://cgi.ebay.com/ebaymotors/ws/eB...category=46100
                I dunno if they are good or not though.
                1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
                  Go back to summit and get the nordskog digital fuel press gauge and sender. I think it is about $60 for the pair.
                  I have that setup and I like it a lot. The electric sender mounts on the scrader valve boss on the fuel injector rail. Then you just have to send one wire into the cockpit.
                  1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
