After my headers and rear end are bought I'm probably going to redo my valvetrain. I'm looking for the best combo in roller-rockers, cams, lifters, springs, etc. Any ideas?
3.8 Cam Questions
You don't really need to worry about the rockers too much, they aren't that big of a priority. As far as cams goes, hit up zzperformance.com. They have some pretty good Cams, their gt2 cam is one of the best. Also, some type of lightened pushrods I am thinking aluminum or chromoly. LS6 Springs.
Most important.. TUNE THE CAR AFTER THE INSTALL.
This will yield the most gains, anywhere from 10-35 horsepower more, against untuned.FTRA kit, Whisper Lid, free ram air mod, Richmond 3.73 gears, Dynomax Catback, Poly Tranny mount, Vette Wheels, Expensive Audio equipment :). HID headlight Kit, Billet Grille, Billet Antenna, Eurotails, Carsound Cat
The GT2 sounds good. Seems like a lot of guys are praising this cam. However, zzp only has one type of pushrod, and I don't know if they're lightened or not. I'd assume so.
Found the LS6 springs. Cool.
I'm getting roller-rockers either way. I'm redoing the valvetrain so why not go all out? Every supporting mod only decreases the chances of a mishap, if done right.. right? How are the ones zzp offers (Pro Magnums)?
Also, if I go with the zzp pushrods, gt2 cam, and ls6 springs, which ratio would I go with on the roller-rockers? 1.6/7/8?
Thanks, Perry!
GT2 cam is what i have, its a nice cam. Very street freindly once mine was tuned.
ZZP sells Comp. Cams Hi-Tech rods. They are chromoly 4130 i think. They are good.
www.abbottracingheads.com Check them out for cams also, they are great guys.
Springs i'd go with Comp. Cams 105 lb. springs
1.6 ratio is what i would stick with on your stock heads.
If you are going all out get some heads from abbott racing.2001 V6 Camaro - VTEC Badged, Abbott Racing Heads Sticker, and Loud A$$ Exhaust<br /><br /><b>BUILT NOT BOUGHT</b><br /><br />14.0 @ 96.44 MPH (Street Tires, Before Tranny)<br /><br /> <a href=\"http://members.cardomain.com/6pakcamaro54\" target=\"_blank\">http://members.cardomain.com/6pakcamaro54</a>
Okay, so I'm going with... (with a few questions at hand..)
All but the ported heads/intake are from ZZP:
</font>- Stage 2 Abbott Racing Heads (comes with LS6 springs)</font>
- Abbott Racing Ported Intake Manifold</font>
- CompCams GT2 Cam (should I go with the GT3? I'm not going to stroke, but...)</font>
- CompCams Hi-Tech Pushrods (which size to go with?)</font>
- SI Stainless Valves (again, which sizes?)</font>
- ProMagnum Roller-Rockers (1.6/7/8?)</font>
- Should I go with Roller-Lifters?</font>
Anything else I should add?
Comp 105lb springs
Comp Lifters (We have stock roller lifters/cam)
Comp Hi-Tech Rods (size depending on heads)
Abbott Cam/Heads
1.6 Roller Rockers
Cometic Head Gaskets
Give Abbott Racing a call. They are great guys and will point you in the right direction about any question you have about it.2001 V6 Camaro - VTEC Badged, Abbott Racing Heads Sticker, and Loud A$$ Exhaust<br /><br /><b>BUILT NOT BOUGHT</b><br /><br />14.0 @ 96.44 MPH (Street Tires, Before Tranny)<br /><br /> <a href=\"http://members.cardomain.com/6pakcamaro54\" target=\"_blank\">http://members.cardomain.com/6pakcamaro54</a>
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...18 hours ago
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....5 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.5 days ago
