i got HP Tuners basically just to recalibrate the PCM for the gear ratio change and change in injector size...but what would be some other good modifications to make to the PCM to get the most power out of it...i'd like to be able to just flash it one way because i dont have a lap top to be able to quickly change it back...the motor is just stock, NA, daily driven...im running high dry shots of nitrous at the track...so i guess im looking for some really good NA tuning that i will also see some benefits with while spraying (timing..aif/fuel mixture..etc)...any suggestions? [img]smile.gif[/img]
HP Tuners tuning suggestions?
<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Tags: None
Well You're not going to have the best of N/A and Sprayed unless you run a dual setup.
Timing advanced until you see knock then back it off a few * for N/A and that is a big NO for Nitrous.
spraying a 100 dry shot MAYBE retard timing 2* make a test run if you see knock, which I doubt, retard it a little more.
A/F You can usually lean it out a bit for N/A to pick up some more HP, but again the opposite for Nitrous. You want to make sure you have plenty of fuel when spraying.
These are general concepts not exactly what to do obviously. Air/Fuel and timing go hand in hand if you adjust your A/F mixture and lean it out for example and had already advanced timing you may be more likely to see knock. It just takes a lot of testing, monitoring, and patience.
You can get a LOT of tuning help from HPTuners forums.
hmmmm....so do you think it would be best to just leave it as is for NA? ..maybe just change the total timing a little for nitrous use?...i really gotta get a lap top and save an NA file and a spray file...then just switch em at the track
[ November 15, 2004, 10:31 AM: Message edited by: 1DangerousV6 ]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
^^yup thats actually what i was doing...just something good enough to have HP Tuners on it [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
well i definitely want to run at least a 100 shot....which means im looking at a lap top RIGHT now lol...its gonna be sweeeet [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...6 days ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.4 weeks ago
