i already have the comp 210 220 512 512 115lsa cam installed. would it be a bad idea to install 1.8 ratio rocker arms to push my lift to .563??
cam and rockers a bad idea???
96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHRTags: None
I may be doing my math wrong, but I'm getting .576 Lift?
.512/1.6=.32
.32*1.8=.576
.576 is pushing it, If you have comp 130# springs and titanium retainers you may be able to get away with it, but I'd replace the pushrods, throw in some comp valve locks and viton premium valve stem seals for assurance, while your in there may as well do lifters ;)
i do have 130# springs and titanium retainers. and the kit from SLP has the pushrods. i do want to get new lifters, and the seals and locks are pretty much a must I thought. with my intakes and heads port matched and polished to handle the lift, you think it'll be alright? you are right with the lift, i was estimating.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
well, i guess that settles it. it will be done. if 1.6-1.8 gave a stock cam 10hp, do you have a guestimation on how much it will give my aftermarket cam? basically, anything above a 10hp gain is awesome with me.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
If you're talking about having 0.576 lift on stock heads, you'd better stop dead in your tracks. Our heads stop flowing efficiently over 0.500 lift pretty much when stock from what i've read around so i would def not go anywhere near .576, those rockers are meant to increase lift for people who dont have cams. If you want to shell out that kind of money, Intense has a really nice set of harland sharp 1.6 roller rockers for $400 plus another $100 for their lightweight pushrods or get the comp hi-tech pushrods for $100 and you'd have better rockers and no lift complications.
http://www.intense-racing.com
"The 1.60:1 (same ratio as stock rocker arms), INTENSE™ Full Roller Rocker Arms are a complete bolt-on kit designed for use with aftermarket camshafts."1997 Pontiac Firebird 3.9L<br /><br /> - TSP Dyno Tuned<br /> - Bored 0.040<br /> - ARP Rod Bolts / Head Studs<br /> - Custom CAI<br /> - Pacesetter Ceramic Headers / !Cat<br /> - 3\" Catback w/SLP Firehawk Muffler<br /> <a href=\"http://www.cardomain.com/memberpage/649312\" target=\"_blank\">http://www.cardomain.com/memberpage/649312</a>
what would be stock about my heads? i'll have them ported and polished for the lift, new springs, retainers, locks, seals, pushrods and lifters. what else would i have to do make this a safe mod??
[ November 16, 2004, 02:11 AM: Message edited by: Timmy ]96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
You have them ported and polished for the lift... That is very vague. If they were ported, they will FLOW fine with the high lift, but the VALVE GUIDES stick up to high, you have to specifically tell the machine ship to MILL THE VALVE GUIDES down to accept any more lift.
There is a HUGE difference between "ported and polished for the lift" and "valve guides milled so there isn't a valvetrain collision"
Check into it.1997 Chevrolet Camaro v6 - 13.8@104MPH
1997 Dodge Viper GTS
how much milling has to be done for the 1.8's to work? will that effect the lift at all?96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
how much of a problem would it be to do the 1.7's and i do know what you are talking about AZ. i just had to look at it to see it if you know what i mean.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
i just talked to zoomer at zzp and he said that i can do the 1.7s with zero problems. no milling of the valve guides. so, i guess im going to do that then. thanks for helping me figure this stuff out guys.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
