Alright, in the LS1 aftermarket, this code is a known issue. It stems from aftermarket headers getting rid of heat faster than the O2's would like, and they don't switch as they should. For background, my car has fresh Bosch O2 sensors on it, and until it got cold here about 2 weeks ago, I had no SES light thrown.
With that said, the LS1 guys are replacing their front O2 sensors with the C5 Corvette's REAR sensors. They say that these sensors' heaters stay on longer, and appease the PCM, and still read correctly and the PCM will still adjust the A/F accordingly. Also the harness from these sensors is longer, and for those few V6 guys who have ended up needing extensions would not need any extensions!
Any experience with this? MAGNUS and others who have swapped motors: Are the LS1 sensors, the rear vette sensors in particular, compatible with our V6 front sensors as far as the PCM is concerned?? Are there any downsides to using the Vette's rears sensors?
