This guide may or may not be challenged by the opinions of others, but who cars.
First of all we have OVERDRIVE!
Why i havent seen most of you guys use higher stall torque converters is beyond me. Its been proven over and over that a higher stall torque converter will increase performence noticeably.
Gearing, this is an issue with most people, but from what many have told me in the past by the word ont he streets. 4.11's are most likely the best choice for our v6 or you could try try 4.56
LSD is a must if you dont already have this get it now!
Better traction is always good, lower control arms, torque arm if you can come across a cheap one, aftermarket springs.
Any simple weight reduction is great as long as its not from the rear end to much.
I seriously think its rediculous that anyone would buy supersix heads. the 98+ 3800 v6 heads flow enough, porting them and your intake would be the just as good as buying whole new heads.
IMPORTANT...
air/fuel tuning, engine cooling, air/exhaust flow, good spark are all essential in running good performence. Upgrading Fuel Pump from stock is always a plus.
I see people using aftermarket MSD's which is non-sense. the stock MSD is well good enough.
Cams, this is a subject it seems not many like to get into because it requires real thinking.
Depending on your setup how much air flow/fuel and exhaust is coming and going certain cams may not respond well, its up to you to find out what you are running and which numbers will benifit your setup.
Running your 3800 v6 with a good
well flowing intake/tuned fuel deliveryfuel/well flowing exhaust to match intake/matched cam/4.11 gears/higher stall torque converter/reasonable traction mods, this will take your car into low 14's
add low boost supercharger or turbo... you just made a low 13 second car do a little more work, now you hit 12's with a v6.
[ September 08, 2003: Message edited by: Swift_3800_F-Body ]</p>
IMPORTANT...
