What is the largest 3.4 cam that you guys know of, or would reccomend. I think the largest i see is the 226-236 Comp on Full throttle's, or the 228* 228* by lunati.
Largest 3.4 Cam?
Here's my cam card.
I do know that Crane makes a bigger one with a power band of 2800-7000 or something like that. I don't remember the rest of the numbers.
Search on the crane cams site. They make a realy mean mechanical cam.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
The CompCam custom grind is also a huge cam. If you want to go big, it will have to be a custom grind. The shelf cams are not made to be too radical.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
Originally posted by Jerriko's Garage:
Here's my cam card.
Low end?All black 94 3.4L Camaro <br />5 speed with t-tops<br />Mods-<br />Cold air intake, Duels no cat<br />Iroc rims, Manual fan switch
Originally posted by Dotyereye:
</font><blockquote>quote:</font><hr />Originally posted by Jerriko's Garage:
Here's my cam card.
Low end? </font>[/QUOTE]Runs good. It has a little roughness in the idle but not too bad. Driveability is good. It has plenty of low end torque and responses great to nitrous. :D I will be getting the larger one this winter but it will be a custom grind. They don't make a roller version. I found the specs for it:
-248/258 duration
-534/555 lifts w/ 1.6 ratio rockers
Crane Cam
Originally posted by viper98885:
The CompCam custom grind is also a huge cam. If you want to go big, it will have to be a custom grind. The shelf cams are not made to be too radical.Wolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
Originally posted by wolf:
</font><blockquote>quote:</font><hr />Originally posted by viper98885:
Originally posted by Jerriko:
</font><blockquote>quote:</font><hr />Originally posted by wolf:
What is the benefit of having a higher exaust for instance the 226*236* on the comp, rather than the 228* 228* on josh's lunati. Also can someone explain why people use the split ratio rockers when they run the comp (226*-236*) cam, like dakota used. Which cam will i be better off with assuming i want a lopey, mean sounding idle that doesn't sound like it's going to stall out. Also, if anyone can find other cam sound clips of like crower, can you send em. Josh, i would really like to hear yours, lol can you post a link, or even wolf? thanks guys
If you do a custom grind, you should really base them on your flow numbers. Getting a cam that is matched for someone else's numbers will not always offer the best performance. Also, just because it's a high lift or high duration cam does not make it the best for your application.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
