well just want to know whats the diffrence between the 1.9 INTENSE Roller Rocker Arms and the I Win Engineering 1.90 roller rocker arms they both claim the same hp and also i know if doing the 1.9 u need to put ls6 springs i just want to know which is better i know that i win $274.00 and the intense is like 369.00 so what are your guys thoughts the only reson im ask is im want to install roller rocker but just dont know which one to use so far 274.00 sound pertty cool but dont know if they suck so anyone with these sent up let me know too thank for the help
whats the diffrence of the two
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainersTags: None
I Win: Modified stock rockers.
"Intense": Custom roller rockers made by Harland Sharp.Matt
1998 Mystic Teal Camaro M5
anything else besides that^?2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
Originally posted by Kal-El:
anything else besides that^?Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by AZ3.8Camaro:
</font><blockquote>quote:</font><hr />Originally posted by FirebirdGT:
</font><blockquote>quote:</font><hr />Originally posted by Kal-El:
anything else besides that^?Matt
A cam would do you better than the rockers.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
intense 3rd gen rockers are aluminum roller rockers. less valvetrain friction and less valvetrain mass. they reduce mass of the valvetrain by the weight of one piston. they also for sure come with reusable rocker bolts.
the iwins are not roller tip and they are pressed steel rather than aluminum.
the ls6 spring upgrade is not a joke. you will understand if you install the rokers with out upgrading the springs and feel valve float at 5500 rpm.
if you are doing it yourself but would rather not tear into the motor so far as to upgrade the cam then they do add SOTP horsepower. If you are paying to have it done then it might be a REAL expensive modification and maybe not worth the gains. If you plan on upgrading the cam in the future then don't get high lift rockers.
There's a bunch of threads on clubgp about problems people have been having with the intense rockers. Apparently the roller tip is eating into the side of the rocker, sending aluminum shavings into the engine.
I know a fix has been release, but I'm not sure how far it's been tested. Intense has become a fairly controversial company in the 3800 community, particularly in the GP world.
May want to go over to clubgp and do some research.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
cool thanks for the info guys2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
DOH!
Less mass mainly just means more rpm for the valvetrain.
If you are on a stock limiter it doesn't mean much. Roller tip offers marginal gains.
The only increase in power would come from more lift, and again it seems marginal on stock heads.1997 Chevrolet Camaro v6 - 13.8@104MPH
1997 Dodge Viper GTS
Raven
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...18 hours ago
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....5 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.5 days ago
