i think i can make one in my class if i can would this be feasible to put in or would the comp get all jacked up?
3.4 tb spacer??
keep TB colder, If you can do it cheap go for it. Won't gain much, I still like the idea a guy with a n LS1 gave me, since I did a TB bypass, to run 2 hoses to the windshiled washer fluid, and put ice water in the resovoir, so you basically have ice water running through the throttle body. if I get bored one day I might try it.
that might be cool let us know how it works
;)1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
<blockquote>quote:</font><hr>Originally posted by Tiago NOS'd Bird:
it wont keep the TB that much cooler and it wont get you any hp. <hr></blockquote>
I jsut knew on ohter cars people have done it was not sure on 3.4L, But if oyu can do it try it might help a teenie bit, no more then TB bypass.
I read somewhere of someone doing the tb bypass, & took it 1 step further: They took a small funnel,put it in the fron tof the car, connected hose from the end of the funnel to one openin gof the tb. That way it would cool of the tb some. not sure if it works, but sounds feasible.1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
