Electric Water Pumps - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Originally posted by Kal-El:
    well its not like it draws a lot of energy only 9 amp would be used. so i would see the problem on that
    Never said it took alot. The mechanical pump doesn't take much energy either. The point is that it won't actually free up any power. Takes the same amount of energy to turn the pump, regardless if it's mechanical or electrical.
    Matt
    1998 Mystic Teal Camaro M5
    • #17
      The only reason i would buy an electric pump would be to pull my belt at the track and be able to still have a water pump. Not having near the risk of overheating.
      2001 V6 Camaro - VTEC Badged, Abbott Racing Heads Sticker, and Loud A$$ Exhaust<br /><br /><b>BUILT NOT BOUGHT</b><br /><br />14.0 @ 96.44 MPH (Street Tires, Before Tranny)<br /><br /> <a href=\"http://members.cardomain.com/6pakcamaro54\" target=\"_blank\">http://members.cardomain.com/6pakcamaro54</a>
      • #18
        wow... depressing, but that makes ALOT of sense. i never even thought about that. thanks ALOT for the info. I'd be a really cool thing to have, but since im not on the strip too much it'd be pointless. huh... that explains y RPM's dip when i hit the defroster grid.
        2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
        • #19
          i still think its a worthwhile mod if you gotta do a water pump anyways..
          96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
          • #20
            I've had my electric wp on for over a year now. it provides more of a hp gain as rpm's go up. This may sound strange, but here's why. as the rpm's go up on a stock wp, it takes more hp to turn it faster, causing more of a loss at higher rpm's than at lower rpm's. when you switch to an electric one, you gain very little low end, but you do gain more as rpm increases. at 6000 rpm, I could see gaining 10 rwhp on a moderately modified car. If you increased the rpm limiter even more, you'd see even more of a gain over a stock wp. I did this in conjunction with a 160* thermo and a coolant flush, so it kinda made sense to do it all at once.
            • #21
              arctc wolf did u have any problems with your belt sliping not completey off the tension pully if so how did u fix it and if not how did u rout the smaller belt for yor eltric water pump mine keeps on sliping not off but its half on and half off thanks i wish i can show a pic on here but dont know how to put one on here any one know how thanks
              2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
              • #22
                Kal-el....
                I'll answer that question as if u asked me..
                Mine doesnt slip. But i do have abrand new Tensioner pully.
                if u'r pully has any wobbble in it, it will throw it off.
                also what belt are you using?
                mine is part number GB6-985 i think. its a gatorback
                • #23
                  I routed it the same way as it used to run, except without the wp pulley. it never slipped off. I run a belt about 5 inches shorter than stock.
                  • #24
                    well the belt im useing is 887 k6 is tight i dont know how many inches it is from stock? so u think my Tensioner pully is bad then? when i had my regaler set up it never sliped off and now that i swiched it all of a suden it does this and i think i drain power when im at idale my volts drops lowsometimes past 13 but when im driveing its all good. to be honest im have all of this problem makes me thing i shouldnt of got this i was doing fine with my old set up i dont i dint feel much power anyways but know if its because the issuse of the tensioner pully i dont know
                    • #25
                      you should be using 905k6 which is 4 inches shorter than stock.
                      g
                      2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
