No one has really said anything about this. I am going to install it...is it as simple as taking off the belt then a couple bolts then bolting the new one in and then putting the belt back on? Like can i just off and put the belt back on by hand?
Installing water pump pullie
This topic is closed.
dude, it's the easiest thing to do. Just four small bolts. Remove the belt by using a wrench / bar on the tensioner, swap the pulley, belt back on. Done in like 4 minutes or so.<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
No one has really said anything about this. I am going to install it...is it as simple as taking off the belt then a couple bolts then bolting the new one in and then putting the belt back on? Like can i just off and put the belt back on by hand?Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
ZZP, that is corret...i was just making sure that i didn't need to do anything funny.
Remove the belt by using a wrench / bar on the tensioner...why on the tensioner?2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
Remove the belt by using a wrench / bar on the tensioner...why on the tensioner?<a href=\"http://www.onid.orst.edu/~waltejam/\" target=\"_blank\">98 Bright Red Camaro</a><br />Too many mods to list....check my website
Originally posted by Wicked 3800 V6:
Yeah, geez, you might be overwhelmed by those little 8mm bolts. Might break off your arm or something. [img]graemlins/stickpoke.gif[/img]www.turbov6camaro.com
1997 3800 Series II Camaro
Why mess around with a pulley when you can just buy an electric water pump?
- Justin<a href=\"http://www.njfboa.org\" target=\"_blank\">New Jersey F-Body Owners Association</a><br />1987 Camaro LT - 400sbc, Aluminum L98\'s w/valve job, Comp XE 274, Q-Junk 750, 3.23 posi, 4.10\'s soon.<br /><br /><a href=\"http://www.njfboa.org/forums/viewforum.php?f=11\" target=\"_blank\">East Coast F-Body Nationals - August 14, 2005</a>
loosen the bolts while the belt is still on. that way the pully will not move.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
