Installing water pump pullie - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
  • Installing water pump pullie
    No one has really said anything about this. I am going to install it...is it as simple as taking off the belt then a couple bolts then bolting the new one in and then putting the belt back on? Like can i just off and put the belt back on by hand?
    2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
    Mechanically, yes, that's it. I would suggest that you break the bolts loose that are holding the pulley onto the water pump before you remove the belt. It should be easier that way. Are you changing any other pullies also?
      dude, it's the easiest thing to do. Just four small bolts. Remove the belt by using a wrench / bar on the tensioner, swap the pulley, belt back on. Done in like 4 minutes or so.
        Yeah, what he said. This is hardly advanced tech.
        2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
          What pulley are you installing? ZZP?
          Raven
            ZZP, that is corret...i was just making sure that i didn't need to do anything funny.
            Remove the belt by using a wrench / bar on the tensioner...why on the tensioner?
              Are you sure you can change these bolts by yourself?
                Yeah, geez, you might be overwhelmed by those little 8mm bolts. Might break off your arm or something. [img]graemlins/stickpoke.gif[/img]
                  or break the bolts any really be in trouble [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img]
                  www.turbov6camaro.com
                  1997 3800 Series II Camaro
                    Why mess around with a pulley when you can just buy an electric water pump?
                    - Justin
                      loosen the bolts while the belt is still on. that way the pully will not move.
                      1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> &lt;Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> &lt;Fbody Tech Articals
                        General tech..........
