Ive had it replaced 3 times in the last 1,000 miles!! They have been under warranty but what could the problem be! IS is possible that pressure is being built up and is breaking the seal???
OIL PAN GASKET!!
I've heard the cork gaskets that GM dealerships use suck. I replaced mine with a rubber gasket from NAPA and it worked fine. Not sure if that'll help you with the warranty work though.\'98 Camaro V6<br />Appearance... pleasing<br />Performance... just a little extra air.
could be that the oil is coming from a source higher up and hitting the oil pan gasket and "wicking" around the oil pan gasket making it look like the pan gasket is leaking, after being replaced 3 times sounds like people other than "pros" working on it.2005 Magnum
Originally posted by NCState98:
I've heard the cork gaskets that GM dealerships use suck. I replaced mine with a rubber gasket from NAPA and it worked fine. Not sure if that'll help you with the warranty work though.Jim Carrey looks like me
Make sure and use a little RTV on the area of the pan gasket that meets up with the front and rear main seals. The gasket edge that sticks down from the rear main is not usually flush with the cover, and it protrudes a little bit. Fill in the area with RTV...1997 Chevrolet Camaro v6 - 13.8@104MPH
1997 Dodge Viper GTS
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...1 week ago
by ssms5411Getting a message saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...1 week ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.2 weeks ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...2 weeks ago
