OIL PAN GASKET!! - FirebirdV6.com/CamaroV6.com Message Board
OIL PAN GASKET!!
  • OIL PAN GASKET!!
    Ive had it replaced 3 times in the last 1,000 miles!! They have been under warranty but what could the problem be! IS is possible that pressure is being built up and is breaking the seal???
    Mystic Teal Metallic
    is it chunking apart from underneath the crank, just leaking, what????
    What condition is your oil pan in, especially around the seal lip?
    Jim Carrey looks like me
      everything looks good new gaskets every time installed by pros... and its lust leaking but the gasket looks good but we know its coming from the gasket because of the dye!
        I've heard the cork gaskets that GM dealerships use suck. I replaced mine with a rubber gasket from NAPA and it worked fine. Not sure if that'll help you with the warranty work though.
        \'98 Camaro V6<br />Appearance... pleasing<br />Performance... just a little extra air.
          could be that the oil is coming from a source higher up and hitting the oil pan gasket and "wicking" around the oil pan gasket making it look like the pan gasket is leaking, after being replaced 3 times sounds like people other than "pros" working on it.
          2005 Magnum
            Replace the front and rear mains along with the pan gasket. (Or if it is coming from the back of the pan only, just the rear main)
            1997 Dodge Viper GTS
              Yes, what he said.
                what cork seal?????????? mine, that I got from the dealership, was a one pice windage tray looking thing.
                  already replaced the rear main seal
                    Make sure and use a little RTV on the area of the pan gasket that meets up with the front and rear main seals. The gasket edge that sticks down from the rear main is not usually flush with the cover, and it protrudes a little bit. Fill in the area with RTV...
