i order a ecm from a junk yard and it got here today but it was out of a 99 buick la sabre and when i put it in the engine want even turn over anymore so i put the old ecm back in and it turned over so is the ecm not compatiable. They asked for the numbers on the front of your ecm and i gave them the # and the # match up on mine and the sabres so are they compatable or not
it would most likely need a reflash, the hardware might be compatible, but the strategy/OS might be different.
Ryan
1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
Originally posted by therock: i order a ecm from a junk yard and it got here today but it was out of a 99 buick la sabre and when i put it in the things want even turn over anymore so i put the old back in and it would still turn over so is the ecm not compatiable they asked for the numbers on the front of your ecm and i gave them to them and the # match up on mine and the sabres so are they compatable or not
Sorry, dude, that is very hard to read. FWD ecms are not compatible with RWD cars.
sorry is confusing to me to bt thats the best way i oculd actually say it so is the sabre a fwd car i dont know much aboiut them just that they do have a 3.8
The lesabre is a front wheel drive car. It has the 3800 engine though. Its funny this came up now. Just a few mins ago I was thinking of trying to read the codes in my uncles 99 lesabre with my hp tuners. Good luck with getting you money back though.
~Tom
1994 Camaro: Firebird Interior, 3.4L to 3800 converted, OBD2 converted, A4 to M5 converted...In the turbo retirement home...<br /><br />1994 Mustang GT: 347 Forged Stroker, Port Matched Edelbrock Heads and Intakes, Tremec 3550 T-5, Spec Stage 2
Originally posted by tdz16: The lesabre is a front wheel drive car. It has the 3800 engine though. Its funny this came up now. Just a few mins ago I was thinking of trying to read the codes in my uncles 99 lesabre with my hp tuners. Good luck with getting you money back though.
~Tom
you should be able to read almost any GM OBD2 car/trunk with HP tunners scan tool, you just can't edit anything
www.turbov6camaro.com 1997 3800 Series II Camaro 4600 Stall for my ride to the mall :chug: 7.18 @ 99.77 1/8 -1.8x sixty (current quickest v6 fbod) 11.23 @ unk 5 1/4 - 7.19 1/8 - 1.83 sixty
It is the same part number... But it has a different program stored in it. You have to get it reflashed with the correct program for your car. By a dealer or by a tuning package that can load the correct year/model program into your pcm.
Originally posted by Jerriko: </font><blockquote>quote:</font><hr />Originally posted by therock: i order a ecm from a junk yard and it got here today but it was out of a 99 buick la sabre and when i put it in the things want even turn over anymore so i put the old back in and it would still turn over so is the ecm not compatiable they asked for the numbers on the front of your ecm and i gave them to them and the # match up on mine and the sabres so are they compatable or not
Sorry, dude, that is very hard to read. FWD ecms are not compatible with RWD cars. </font>[/QUOTE]Click here Then go to the dealer and see if you can get a reflash.
Your sig is the most important part of your message. Make sure that you list EVERY single thing that you have done to your car so that we can all go \'oooh!\' and \'Ah!\'. Please make your sig consistently longer than anything else you post. Please include your lengthy sig with EVERY single post you make during a reply, even if you only reply with a monosyllable grunt.
Some of the FWD 3.8 ECM's have the same service number as the Fbody, but not every year.
Even if the service number matches, for everything to work correctly you may also need to have the ECM reflashed by a dealer. Alternately, send it to Texas Speed or another shop that offers tuning and have it performance flashed.
my service # is 09361735 does anyone else have that. Im going to call the place i got the ecm from and give them this Service number 9374997 and see if they can find any
