info from supersix about oversized valves let me hear your opinions - FirebirdV6.com/CamaroV6.com Message Board
  • info from supersix about oversized valves let me hear your opinions
    tom told me it would cost 20.00 a valve for oversized valves. my question is what will i benefit from this and about how many hrsp gain is it? is it worth spending the 240.00? sorry dont know if this belongs here, each time i post anything about motor in gen tech it gets moved here so here goes [img]smile.gif[/img] would bigger exhaust valves give me any hrsp gain?
    From what ive Heard the over sized valves arent gonna do much good unless you got forced induction whether it be N2o or a BLOWER. Cant remember who i heard that from but i know i read it somewhere on the board.
    2001 Black S10 Xtreme 4.3L A4<br />*RedLineVSix*<br />\"Throwin sparks, draggin frame\"
      I would use the money elsewhere.
      With bigger valves, you get more cylinder wall scavenging.
      I don't know if you would gain HP. Only real way to find out would be to get the heads worked, put them on the car, dyno, then send them back for bigger valves and dyno again.
      I don't know of anyone with bigger valves on their NA 3800 either.
      Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
        <blockquote>quote:</font><hr>Originally posted by Magnus:
        <hr></blockquote>
        Magnus, I think you mean more shrouding, not scavenging. This is very possible when adding larger valves. Necessary steps must be taken to unshroud the valves or you very possibly could loose power.
        I wouldn't mess with the larger valves until someone proves they are worth the money with the 3800s. Stock valves w/ a nice valve job and the necessary porting will be all that most will need.
        Bigger is not always better. :D
        [ January 19, 2002: Message edited by: Jason99T/A ]</p>
        <b>99 Trans Am- Bright Red 6 speed</b><br /><br /><a href=\"http://thunderracing.com/projects/?action=read&pgid=86\" target=\"_blank\">348ci forged shortblock, Thunder Racing ported 5.3l heads, Cam Motion 246/250 110lsa hyd. roller cam, Moser 12-bolt (4.56/spool)</a><br /><br /><b><i>10.32@131.70, 1.43 60\' - 3238 raceweight, +675\' DA</b></i>
          well, let him get the oversize valves and be the guy that tells everyone else if they are worth it, if he wants to that is. always has to be a first person to try it.
          [img]graemlins/monkey.gif[/img]
          [ January 18, 2002: Message edited by: dstrbd1 ]</p>
          you can\'t get off if you don\'t get on
            i would but like magnus said the only true way to tell would be me getting it dynoed with stock valves and then pulling heads again and getting oversized valves then dyno again, hey im being the first to get the 3800 fbody bored .030 over someone else can be the guinea pig for the valves :D
              I definitely wouldn't get larger valves for an n/a motor.... even a n2o motor that's shooting less than a 150shot. Save the big valves for when you're pushing 10psi + of boost via blower or turbo.
              When are you supposed to get the block bored .030 over?
              GM 3800 PowerPak guinea pig<p>\"what cam, that\'s just a nasty mis-fire...\"
                its in the process as we speak, the machine shop guy said it will be finished around the end of this month.
                  How much was it to get it bored out? And don't forget to tell us about the hp gains.
                  Free Ram Air Mod<br />2001 m5 v6
