Quick Question about the VS Cam - FirebirdV6.com/CamaroV6.com Message Board
  • Quick Question about the VS Cam
    I may actually be ordering this cam tonight if I can get an answer. What all do I need to order with the VS cam? I assume you would also have to have the cam install kit but I noticed the last item on the contents list is 1 Supercharger Gasket, would this kit still work with our cars? Assuming the cam and install kit work and even if it only gives 20-30 hp thats not bad for $300.
    <a href=\"http://community.webshots.com/user/maniacls1\" target=\"_blank\"><b>2001 Firehawk #155 of 504 -M6</b></a><br />437 RWHP / 404 RWTQ -Dynojet (heads/cam)<br />12.34 @114 mph 1.7 60\' (bolt-ons only)<br />12.47 @116 mph 2.0 60\' (street tires, heads/cam)
    All you need out of the install kit is the Rocker arm bolts, upper/lower intake gaskets, front cover gasket, timing chain. You can probly get them all cheaper from GM.
      In that kit, the intake gasket on the top left is totally different, the others ones look about the same though. The valve cover gaskets look different too and not sure if you need the rocker bolts. Look here: http://www.camarov6.com/cgi-bin/ulti...&f=16&t=001097
      I've listed everything I'm taking tomorrow morning with me to get the cam installed. As well as cam, springs, retainers, pushrods, oil, filter and coolant.
      1997 Nassau Blue Vette<br />1989 Jeep Cherokee 4x4 (lifted with 31\" tires)<br />2000 V6 Camaro, loud, cammed 210rwhp *SOLD*
        The VS cam is designed for a L67, wouldnt one of the L36 cams be a better choice?
        1997 Red GTP Coupe<br />Borla,3\" DP,!ubend,Thrasher CAI,Magnuson(3.4\"),1.9 roller rockers,Tran. Cooler,GPS PCM,Boost+Trans. Temp gauges(in Lotek),comp harness,Blazertech 3200\'s,BBS 18\'s+Pilots,RAT rear sway bar,Powerslots+Pf Pads(all corners),KYB\'s,STB\'s,Poly bushings(mid+end),Optima Battery(yellow), Kenwood Deck+Boston Interior Speakers(Pro)+RF Sub(550 watts), GTS covers,rear red reflective Pontiac sticker(My fav.)
