I really need the part number for replacement lifters or if there is a better set.
anyone have the part number for lifters
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport HeadersTags: None
Good post, I have seen some lifters that are a far cry better than stock (but cant remember where they were). They were a moly coated set and were extremely light and strong, looked intriguing... the guy running them gained around 2rwhp over normal lifters, which isnt bad [img]smile.gif[/img] I'll look around!
I don't think when it comes to lifters you need (3800-II special lifters)... just some kind of size/length/ability. Hang on, going into deep search mode.2002 5-spd NBM Camaro
Details: www.1lev6.com
http://www.delphi.com/pdf/eandepdfs/...HVL-Roller.pdf
I know compcams sells some nice lifters, but damned if i know the right size.
http://www.compcams.com/information/Products/Lifters/
[ December 10, 2002: Message edited by: Dominic ]</p>2002 5-spd NBM Camaro
I had my engine rebuilt and ever since the lifters have clicked!!! :mad: So im lookin at geting a completely new HIGH PERFORMAMCE valvetrain. I like the Delphi lifters, but where can I buy them/ how much?96 Artic White 3800 Series II Camaro <br />Mods: New Engine, SLP CAI w/ K&N Filterchargers, SLP Quad Center Exhaust, LS1 Aluminum Driveshaft, BFG G-Force T/A-KDW 245/50ZR16s, StreetGlow Gold Series Neo-Blue Under Car Glow, and Sony MEX-5DI Color TFT CD Player.
Stock valve lifter could be either of these 2 part #'s:
Just got off the phone with AMM and he said that '98 cars use 2 different style lifters. Im not sure this implies on post '98 or pre '98 but I know for sure '98 3.8's have these two different style lifters.
steel pushrod seat: 17121905
blue pushrod seat: 17122490
There is really no way to tell which one untill you pull your lifter out. I would guess maybe a dealer could run your vin# but im still not sure.
I belive our stock lifters are fine. Any gain would be from a restricted oil metering hole keeping the ratio lifters pumped up during high rpms.1997 Red GTP Coupe<br />Borla,3\" DP,!ubend,Thrasher CAI,Magnuson(3.4\"),1.9 roller rockers,Tran. Cooler,GPS PCM,Boost+Trans. Temp gauges(in Lotek),comp harness,Blazertech 3200\'s,BBS 18\'s+Pilots,RAT rear sway bar,Powerslots+Pf Pads(all corners),KYB\'s,STB\'s,Poly bushings(mid+end),Optima Battery(yellow), Kenwood Deck+Boston Interior Speakers(Pro)+RF Sub(550 watts), GTS covers,rear red reflective Pontiac sticker(My fav.)
