Would this be a decent number... the specs are:
210/210 .507/.507 111LSA Zoomer told me this is an Ideal cam choice. Anyone running this or can tell me my car's characteristics and HP/TQ change after the swap? Thanks
I concur exactly with Magnus. 111LS is gouing to be extremely choppy for a 6, ever hear one on an 8? The 210/210 isn't so bad, but there are better durations out there! Does he have a *reason* for specifying this cam for you? Has it been run with dyno sheets?
As long as you have your intakes ported, preferably his (Zooomer's) new ported intakes then that cam should work fine. You'll be spinning the motor high though, and it would be better if you had an M5 to street it. You'll probably have to drill your TB plate a bit to help the car idle.
<blockquote>quote:</font><hr>Originally posted by THUPERMAN: As long as you have your intakes ported, preferably his (Zooomer's) new ported intakes then that cam should work fine. You'll be spinning the motor high though, and it would be better if you had an M5 to street it. You'll probably have to drill your TB plate a bit to help the car idle.
