not sure of the specs or if they will work, but tell me if someone buys these i want to hear about the results. http://cgi.ebay.com/ebaymotors/ws/eB...category=33617
here are some aluminum heads!!!
96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>Tags: None
yeah, but they are aluminum [img]graemlins/naughty.gif[/img]
jk96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
jk2000 Navy Blue T-top Camaro A4<br />TSP Rumbler <br />Carsound Hi-flo Cat<br />!MAF screen<br />Whisper lid<br />HPP3
Originally posted by chadder:
</font><blockquote>quote:</font><hr />Originally posted by Die Ford V8:
Originally posted by Ian:
They look o-ringed too, like they were used on a 3.4 with nitrous!
jk-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
like they said, no O-ring, and just because they are aluminum doesnt mean they will flow more than an Iron head. The advantages of aluminum heads is they can be fixed, ie. welded, unlike cast iron. You can weld cast iron but it is very expensive. Also, being a factory GM head, the aluminum wont be as clean as an aftermarket aluminum head so welding is also limited with them.<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
jk
its not that they are alumnium that makes them better, its because they are a much better designed head, they will flow more unported than a fully ported iron head
I know, look for the "jk" although aluminum does disapate* heat better than iron.96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
Will those heads work on a 3800II or an old school L32 v6?
I am guessing that they will not. If I am right, you might as well be discussing vtec for our engines.1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
