Is it worth getting a more aggressive cam if you don't port the heads or intake?? and if so what types of power gains would you expect?? ( that might be a stupid question)
question
question
Jeff ..
1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
2002 WS6 T/A.. Bolt ins..448rwhp
2009 G8 GT.. Vararam intake, GXP axleback
1998 Corvette.. Vararam intake, Ti axleback
http://www.fquick.com/slow-v6Tags: None
VS cam without port. With port call comp cam and get a recommended grind based off mods. Roller rockers also kick *** .
[ December 12, 2002: Message edited by: MoreThanAV6 ]</p>1997 Red GTP Coupe<br />Borla,3\" DP,!ubend,Thrasher CAI,Magnuson(3.4\"),1.9 roller rockers,Tran. Cooler,GPS PCM,Boost+Trans. Temp gauges(in Lotek),comp harness,Blazertech 3200\'s,BBS 18\'s+Pilots,RAT rear sway bar,Powerslots+Pf Pads(all corners),KYB\'s,STB\'s,Poly bushings(mid+end),Optima Battery(yellow), Kenwood Deck+Boston Interior Speakers(Pro)+RF Sub(550 watts), GTS covers,rear red reflective Pontiac sticker(My fav.)
The gains to be found in ported heads dont come from porting and polishing, just larger valves [img]smile.gif[/img] If you want more performance from heads, throw some bigger valves in them [img]smile.gif[/img]2002 5-spd NBM Camaro
Details: www.1lev6.com
Thanks for the input.. Would I be able to purchase bigger valves at say like Advance or Autozone or do they have to be specialy ordered??Jeff ..
You know valves aren't exactly bolt-in, right? They're on the underside of the head, not like the rockers which are *cough* only underneath the valve covers. So to just do valves you'd be pulling the entire valvetrain to get to your heads, and you'd need a boatload of gaskets and bolts. Might as well shoot for doing more than valves while you're under there, since you have the expense of all the gaskets / prep / lube / bolts already , which may be more than the darn valves alone.
-Rob<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
