Thinking of a cam for xmas!!!! - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
  • Thinking of a cam for xmas!!!!
    Hey guys! I'm ready for some real performance upgrades. I'm very much considreing gettting a cam. The one I'm looking at now is Comp Cams GT cam. The durations are: 210°/210° at .050"
    Intake Lift .317" (.507" lift at 1.6:1 rocker ratio)
    Exhaust Lift .317" (.507" lift at 1.6:1 rocker ratio)
    113 Lobe Separation
    Let me know if this is a good cam or not. I was considering the G2 cam put it sets off the p0300 code and I dont have the bank to do this engine work annd get it programmed, yet. Also let me knwo if I should change out my springs, pushrods, retainers, etc. I'm thinkin it would be wise for performance gains. If somone knows of a better cam that won't set off the code let me know. Also with this cam or any other cam coul I switch out my 1:6 stock rockers to SLP's 1:9 rocker setup. If not I'll jsut do the cam cuz i knwo the cam will benifit more thn the rockers. Thanx guys for your input.
    01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
    AR stage 3 heads/intakes to be installed
    www.cardomain.com/id/firehawknwv
    www.vaperz.com
    PEWTER MAFIA/ Kristen's "PEWTER MAFIA KING"
    It's 1.9 rockers OR cam. Can't do both (AFAIK), because then you'd have huge lift.
    Decent, mild cam choice.
      1) GT2 cam doesn't always set off SES. I've have mine for 2 months, no lights.
      2) GT cam has been proven do be a fairly good cam.
      3) It's not going to be a simple $300 for the cam. By the time you're done, expect to be around $1500, depending on what you get.
      4) Do a search and read up on cams. They've been beat to death here, and there's tons of info if you just do a search. You asked if you could run 1.9 rockers with the cam. That tells me you either are not familiar with what lift our engines can handle, or more likely don't know how it all works. If that's the case then you really should read and read and read until you understand it, then look into getting the cam.
      Matt
      1998 Mystic Teal Camaro M5
        Yes please search....
        • Manimal
          Coil springs
          by Manimal
        • Manimal
          Newby here
          by Manimal
