Yea I just wasnt fmailiar with the lift our cars can make. I know now i cant' use them both. I'm gonna get a cam. The GT cam looks good for a mild cam. Now I see that Texas Speed can do ECU repgrogramming by mailing in your ECU. So I'll more thatn likely do that no matter what cam i get. If I do this for sure then I'll probably get the G2 cam. Should be a nice gain of 35 less or more from it. Then get reprogramemd and maybe add another 20-30. However my question is still should I go ahead and get new springs,retainers,pushrods and shizzle from Comp. cams. Also will both cams work fine with the stock Torque convertor cuz I wont have the moeny for one of those just yet. So again let me know yoru thoughts.
thinkin of a cam for xmas pt.2
01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
Tags: None
you will need new springs and retainers for both cams...maybe pushrods too for the G2...and as far as i know you can use the stock torque converter..im actually looking into the GT cam myself [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Moderators have the final word. If a thread is locked or deleted, DO NOT start a new thread based on that same topic. They lock or delete threads for a reason.Matt
1998 Mystic Teal Camaro M5
do not use a stock convertor with the gt2. get at least a 3200. i am going up to a 3800stall. and yes you will need springs retainers and pushrods and lifters. i had my gt2 installed at texas speed and tuned.2000 FIREBIRD NBM<br />Thanks to:<br />TSP, ZZP, TCI, Comp Cam, Whisper, GM, Lakewood, TrafficJamz Car Audio,HP Tuner, Alterstart, texas drivetrain and performance, BMR<br /><br />1990 BLUE CAMARO RS<br />1980 z28 <br /><br />venom-vi vice president
