Compcams has Lifters for our car. - FirebirdV6.com/CamaroV6.com Message Board
  • Compcams has Lifters for our car.
    I emailed them yesterday and today they got back with me saying yes we do later today i should find out the part numbers and price for yah just wanted to keep ya updated.
    <b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
    <blockquote>quote:</font><hr>Originally posted by slacker69:
    I emailed them yesterday and today they got back with me saying yes we do later today i should find out the part numbers and price for yah just wanted to keep ya updated.<hr></blockquote>
    Lemme know the part number and I will call for a price.
      FYI: Just because its from COMP won't mean that its a better lifter.
      You need to find out things like how much they cushion vs stock... they may cushion less which means faster lifts, but harder on valvetrain and more noise... they may also have a different lash requirement.
        all i want is a set of lifters that wont collaspe on me. I figure a company that makes high lift racing cams is gonna have a better lifter than a company who builds race cars for old people. I dont mind the noise i am on my 2nd set of lifters and i can already tell i have collapsed some. If its noise that it produces so be it cant be worse than the noises i hear from my valvetrain now.
          Ok, you really shouldn't be collapsing lifters.. I'd look at WHY they are collapsing first..
          I'd examine the oiling system and valve lash.
            <blockquote>quote:</font><hr>Originally posted by Equis:
            is this for 3.4 or 3.8L??<hr></blockquote>
            3.8L V6...Comp already makes lifters for the 3.4L V6
              Well the reason i have collasped lifters is because of nitrous everytime something goes wrong with the nitrous i end up screwing up the lifters it seems
                And yes these lifters are for the 3.8L
                  What goes wrong so badly that lifters are damaged??
                  Lifters will get damaged if they are being over loaded by either too high of spring pressure, coil bind, piston to valve contact.
                  Do you have stock cam/valvetrain?
                    Well i do have stock valve train but i have a cam on order but wont be in till Jan. The two times i have messed up my lifters are.
                    1. When i was using nitrous after not knowing i had been leakin oil and i was 1/2 a pan empty.
                    2. I reinstalled my nitrous and took it to the track for some runs but somehow the connection for power on my fuel soliniod got burned off and i wasnt getting power to the fuel soliniod so i sprayed a wet shot 100 without fuel.
                      I'd look at oiling issues from when you ran low.
                      I don't think running lean would really screw up lifters. Running lean would burn holes in pistons before lifters collapse I think.
                      Perhaps a few oil passageways are clogged??? Running low on oil is very bad in so many ways. :(
                        any suggestions on what to look at or what to do.
                          Take off the Nos if you dont know how to correcly install and use it.
                          1997 Red GTP Coupe<br />Borla,3\" DP,!ubend,Thrasher CAI,Magnuson(3.4\"),1.9 roller rockers,Tran. Cooler,GPS PCM,Boost+Trans. Temp gauges(in Lotek),comp harness,Blazertech 3200\'s,BBS 18\'s+Pilots,RAT rear sway bar,Powerslots+Pf Pads(all corners),KYB\'s,STB\'s,Poly bushings(mid+end),Optima Battery(yellow), Kenwood Deck+Boston Interior Speakers(Pro)+RF Sub(550 watts), GTS covers,rear red reflective Pontiac sticker(My fav.)
                            Im sorry but i do know how to use it i usally change or check my oil before i spray and one time i for got and there was know way of knowing that the fuel soiliniod power wire had melted off so thanks for your help but no thanks.
                              Did we ever get a part number on those lifters?
