Part #'s needed for cam install - FirebirdV6.com/CamaroV6.com Message Board
  • Part #'s needed for cam install
    Everyone has been asking for part #'s lately. Here are all the part #'s you will need for a successfull cam install:
    1. 12480831 intake set
    2. 24504789 upper set
    3. 25532619 valve cover gaskets, need 2
    4. 24502252 timing cover gasket
    5. 24504668 timing chain
    6. 24503515 rocker arm bolts
    These Part#'s are for a '98 3.8. Most of them should be the same except for prior 98 lower intake gasket set may differ.
    Did I forget any?
    I believe the valve cover gaskets come in pairs..
    I also believe you can get an upper/lower intake gasket kit.
      Yea I remember the '97 gasket set I sold you came with uppers and lowers. But I know the 98 gaskets are different. Maybe its possible that 98 gaskets needs to be bought seperate upper and lower. Is there any way we can find this out?
      And about the valve cover gaskets, can you verify the part # and be for sure it comes with 2 gaskets?
      These are the part #'s I got from GMpartsdirect.com.
      I just need to be sure I am ordering the right parts.
        why not buy the gasket kit. GM Stock Replacement Gasket Service Kit - Includes Gaskets for Cylinder Heads, Intake Manifolds, Valve Rocker Covers and Intake Manifold Seal
        part#12539095
        Cost on gmpartsdirect is $59.04
        <b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
          <blockquote>quote:</font><hr>Originally posted by slacker69:
          part#12539095
          <hr></blockquote>
          Because I dont need head gaskets. Im doing a cam swap only. I have already swapped and installed the heads.
            true but there is a part number for people who are doing it all kinda makes things easier
              bump for me thanks.
