3.4 head work gains - FirebirdV6.com/CamaroV6.com Message Board
3.4 head work gains
  • 3.4 head work gains
    How much of a gain would be seen from porting and polishing the heads & intake, and running 1.6 roller tipped rockers? How about with a 3 angle valve job? All of this on the stock cam.
    Will the roller tipped rockers hit the valve covers or just the full roller rockers?
    I have a 3.4. Current mods are intake and cat back.
    Thanks for any help or advice.
    \'95 Med. Quasar Blue Camaro 3.4 A4<br />Bunch o\' mods<br /><b>10.18 @ 67.60 mph 2.22 60 ft (1/8 mile)</b> <br /><br />-1986 Camaro with a carbed 350<br /><b>8.53 @ 81.45mph 1.8 60\'</b><br />AIM CamaroL32
    Just a port and polish job will not show too much gain. If you do a cam at the same time, you will tell very noticable gains. Neither the roller tipped rocker arms or the full rollers will hit your valve covers.
      I had that setup for a long time, and I saw a good gain, but it can be even better with a cam ;)
        Tiago, did you have a valve job with that or just port and polish, which rockers?
          I have everything, valve job, full port and full roller gold series crane 1.6 ratio rockers...
            CamaroL32: If you're gonna do port/polish, you might as well get a new cam. All the neccesary parts will be pulled off, making a cam install a whole lot easier [img]smile.gif[/img]
            16 years old with no car and big dreams...
              partly right -- the fact that MOST of the necessary hardware will be off (to put a cam in while the engine is in the engine bay, also requires removal of at least the radiator (to fit it in front of the block)) -- but also that, in getting heads, you wont fully realize their airflow potential without a cam and good exhaust/intake system.
              porting/polishing the heads will simply no longer make them an obstacle to airflow. but -- airflow is cutback by the most restrictive part.
              Tiago got heads yes, but he also got headers, and a ported/gasket-matched intake and a LT1 TB. lots of boost of airflow going in and out.
              while a cam would fully realize the heads airflow potential, the fact that he has the intake and heads and headers and exhaust all together, makes it work that much better.
              -R
              hybrid - \'\'hI-br&d - The offspring of a cross between species.
              Co-Founder West Coast F-Bodies
              West Coast F-Bodies Car Club - WCFB Message Board
                Hey Russel, how bout that website? I couldn't get it to pull up.
                I'm looking at doing all this stuff to my car this spring. I'm going off to grad school next fall so I want to be sure my car will last me another 5 or so years. I'm sitting on 127,000 miles right now!! I'm wanting to rebuild, so why not upgrade a little!
                95 Camaro 3.4L A4<br />Bosch plugs/MSD wires, K&N FIPK , Magnaflow catback, hi-flo cat, B&M Shift+, Dee\'s spacer<br />Kenwood KDX-859, eXcelon Amps, Infinity Kappa 3-way doors and Perfect10 sub<br /><a href=\"http://www.cardomain.com/id/harbins95\" target=\"_blank\">Behold, the raw fury that is known as the 3.4!!!</a>
