First off, here's what I had put in. Comp Cams 206/212 113lsa .512/.520, Springs #26-915, Retainer #774 and Pushrod #7939. We had one rocker bolt come lose which was fixed by using the high strength red lock tight. The stock rocker bolts were reused.
It feels really strong from 3,000 rpm up till about 5,000 rpm where it feels like somebody hits the brakes or something, then it pulls through it and gets going about 5,300 rpm on up to the red line. I even had fire shoot out the tail pipes when I didnt' shift till 5,500. I had the Jet Chip in at the time of the flames. Since then, I've pulled that and am running premium gas with no timing advance. It still feels like somebody's hitting the breaks right at 5,000 rpm but it's not as bad as it was with the Jet Chip in. I have had it pull hard all the way up to redline a few times though.
I also can hear a little chatter or something around 1,800 rpm when just sitting there idling, not sure if it's the valve train or an accessory or what, haven't had a chance to get anybody to control the gas for me yet.
Anybody have a clue what is going on, am I running lean or am I getting KR or what? I'm trying to find somebody around here with AutoTap to see what that looks like.
