Making An AutoTap Cable? - FirebirdV6.com/CamaroV6.com Message Board
  • Making An AutoTap Cable?
    Is this even possible? Ive found a place online that sells the OBD 2 connector for 11$, I figure that gives me a pretty good start on building a cable. I've just got to find some kinda of wiring schematic that tells me which wire goes where according to the pin locations on the OBD 2 connector and the serial connector on the other end.If anyone can offer me some help id appreciate it.
    2001 Black S10 Xtreme 4.3L A4<br />*RedLineVSix*<br />\"Throwin sparks, draggin frame\"
    do I search its been brought up before...yes you can do it...
    05' CTS-V
    00' Camaro - SOLD :(
      Umm, I read those posts and i have no idea what the translation box is even for. All i want is the cable so that i can plug it in to A laptop. ALl i want to know is what pin on the obd connector goes to what pin on the serial connector.
        It's not so much an issue for that i don't think, Jason...
        you actually need that box to run with autotap, because the hardware is what helps with the software output.
        now, a hardware schematic would be ideal, what goes where, and whatever else...
        heck, at our next redline meeting, maybe we can *carefully* take the casing off my AT :D
        2011 Camaro LS 6M, in black.
          so there is an actual CARD that you have to put into the computer?
            It consists of a OBD II plug to a serial plug which plugs into that translator box to anouther serial plug and then to your lap top. I would be very interested if somebody could make that OBD II plug to a serial plug and then the translator box. In that box is that lets you either scan all cars or just GM cars or just Ford.
            1997 Nassau Blue Vette<br />1989 Jeep Cherokee 4x4 (lifted with 31\" tires)<br />2000 V6 Camaro, loud, cammed 210rwhp *SOLD*
              Do scanners usually have these translation boxes? My hpp3 for example does not. I wonder if the "box" is just a noise filter?
              2002 5-spd NBM Camaro
              Details: www.1lev6.com
                If your serious check out the pcm resource board..
                http://pcm.dxsoftware.com/forum/
                there's some good info on rs232-VPW converters.
