Is this even possible? Ive found a place online that sells the OBD 2 connector for 11$, I figure that gives me a pretty good start on building a cable. I've just got to find some kinda of wiring schematic that tells me which wire goes where according to the pin locations on the OBD 2 connector and the serial connector on the other end.If anyone can offer me some help id appreciate it.
Making An AutoTap Cable?
Umm, I read those posts and i have no idea what the translation box is even for. All i want is the cable so that i can plug it in to A laptop. ALl i want to know is what pin on the obd connector goes to what pin on the serial connector.2001 Black S10 Xtreme 4.3L A4<br />*RedLineVSix*<br />\"Throwin sparks, draggin frame\"
It's not so much an issue for that i don't think, Jason...
you actually need that box to run with autotap, because the hardware is what helps with the software output.
now, a hardware schematic would be ideal, what goes where, and whatever else...
heck, at our next redline meeting, maybe we can *carefully* take the casing off my AT :D2011 Camaro LS 6M, in black.
It consists of a OBD II plug to a serial plug which plugs into that translator box to anouther serial plug and then to your lap top. I would be very interested if somebody could make that OBD II plug to a serial plug and then the translator box. In that box is that lets you either scan all cars or just GM cars or just Ford.1997 Nassau Blue Vette<br />1989 Jeep Cherokee 4x4 (lifted with 31\" tires)<br />2000 V6 Camaro, loud, cammed 210rwhp *SOLD*
Do scanners usually have these translation boxes? My hpp3 for example does not. I wonder if the "box" is just a noise filter?2002 5-spd NBM Camaro
Details: www.1lev6.com
If your serious check out the pcm resource board..
http://pcm.dxsoftware.com/forum/
there's some good info on rs232-VPW converters.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
