Will my cam thump hard. I want a hard idel. - FirebirdV6.com/CamaroV6.com Message Board
  • Will my cam thump hard. I want a hard idel.
    I have a compcam specs are.
    210/220 .533/.533 115LSA 111 Intake Centerline.
    <b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
    the 115LSA will make it pretty smooth [img]smile.gif[/img]
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      What i really want to know is when i let my car idel will i be able to tell i have a cam.
        i'm gonna say no... it will be hard to tell.
        that cam is a blower cam.
          Yeah i know it is a blower cam thats why i bought it. I am gonna use a blower and spray. SO is it the LSA that is the factor.
            lsa, ramp rates, duration.. really.. overlap..
            the big split might help the chop.. but the 115 will really help smoothen it out.
              But no matter what will i preform well on this cam even NA cause i will be driving NA as well as SPray for like a month before the blower goes on. Also this cam will be easy on the computer with the 115LSA right
                it should be easy on the pcm..
                it will drive fine NA. but its not an ideal NA cam. It's more of a big boost cam. 9+ lbs with restricted exhaust (stock manifolds or non high flow mufflers).
                  It is really for my next motor where i will have 9lbs of boost and a 100 shot of nitrous
                    What about my cam? This is the one I am ordering next week.
                    Comp Cams
                    210/210 .507/.507 111LSA
                    Will you be able to tell I have a cam?
                    <a href=\"http://community.webshots.com/user/maniacls1\" target=\"_blank\"><b>2001 Firehawk #155 of 504 -M6</b></a><br />437 RWHP / 404 RWTQ -Dynojet (heads/cam)<br />12.34 @114 mph 1.7 60\' (bolt-ons only)<br />12.47 @116 mph 2.0 60\' (street tires, heads/cam)
                      Yes you will from what im told the lower the LSA is the harder it will idel 111LSA is the lowest i have seen so far.
                        V6maniac, that cam should idle very similar to mine.. you can tell I have a cam. [img]smile.gif[/img] Its a moderate chop.
                          Ok let me ask it. What bout my cam? Any guesses on how its going to idle
                          218/218 113lsa 110ic
                            that should chop nicely preston.. [img]smile.gif[/img]
                              From what i have heard and seen 115 is the stock LSA in the 3.8 which it does not sound that bad but tends to get raspy in the upper rpm range. Now 114 is a good LSA as i ahve heard quite a few 3.8s with this LSA they have a nice msucle carish idle with not getting to to raspy up top. Of couse the more you go down in LSA the more the idle is going to get chopper and chopper. Please any corret me if i am worng.
                              2004 Dodge Dakota 3.7 litres of raw power!!<br />Nothing but a 6!<br />Do you know for sure? John 3:18
