Useing the 400 or 500hp could burn out a stock trans in a matter of days.
If it slips to start with it won't last long at all.
It has been a while sence I looked at my TH700 tech manual but I think the first thing to go would be the 2-4 shift band.
A corvett servo would be a bad idea for a mod.
You would need an after market fluid pump and a modified valve body. O you have a 98, you would have to reprogram the shift points.
You would have to get a trans built. and get a torque converter to use your new power band.
It is safe to say your car would run like crap if you keep the stock converter.
A 7.5 inch, 10-bolt, and modified (girdled, aftermarket gears and posi unit) would keep you running up to around 400 everyday HP. There was a good article on this in chevy high performance or super chevy a few months back. If you are gonna do 500 HP, I'd look towards a moser engineering ford 9inch....they're rated to like 1000 HP. Have a good holiday.
1994 Camaro: Firebird Interior, 3.4L to 3800 converted, OBD2 converted, A4 to M5 converted...In the turbo retirement home...<br /><br />1994 Mustang GT: 347 Forged Stroker, Port Matched Edelbrock Heads and Intakes, Tremec 3550 T-5, Spec Stage 2
