I am planning on rebuilding my 3.4 in the next couple of weeks, with a cam,1.6 & new valvetrane, bored, and P&P, but with a Holley fuel pressure regulator, do i need new fuel injectors. Someone said to go with 19/hr, but won't that be too much. also, does venom make 17/hr ones, i didn't see them on summit's website. would upgrading to 17/hr Venom ones benefit me more, or will 19/hr from a 3.8 be more beneficial. thanks
********3.4 Fuel Injectors **********
send your stockers to CRUZINPERFORMANCE for cleaning/testing1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
The 3.4 has 17 lb/hr and the 3800 has 22 lb/hr.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
am running 19's in my 3.4 only .3 richer on my rteal time data system. keep in mind all the mods i.e. p&p, cam, & more displacement will lean the mixture so larger injecters might be a good thought. whats the part # on the regulator and is it adjustable. my speed shop guru says nobody makes 1 for the 3.4
am running 19's in my 3.4 only .3 richer on my rteal time data system. keep in mind all the mods i.e. p&p, cam, & more displacement will lean the mixture so larger injecters might be a good thought. whats the part # on the regulator and is it adjustable. my speed shop guru says nobody makes 1 for the 3.4Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
the rteal time data system was a type o. i have a portable data moniter function on my snap on diagnostic reader. i can moniter most all the engine peramiters as i run down the road and log and review like they do in race cars. but its only short term (10-15 min)to catch whats going on when a fault happens. and its only good for very late obd1 and all odb2 systems. as far as my set up i'm yanking eng and trans for p&p, cam, head shave, new clutch, and paint (my wife backed my pick-up onto my hood). might get a chip too. going to see what stock programing will put up with.
am running 19's in my 3.4 only .3 richer on my rteal time data system. keep in mind all the mods i.e. p&p, cam, & more displacement will lean the mixture so larger injecters might be a good thought. whats the part # on the regulator and is it adjustable. my speed shop guru says nobody makes 1 for the 3.4<b>1995 Bright Red 3.4L</b> <br /><a href=\"http://www.cardomain.com/id/94camaroguy\" target=\"_blank\">Carmen\'s Page</a>
Yeah, i was going to have my stock 17's sent out and rebuild, but now i will run them once the cam is in, or just wait and see, then buy venom 19 hr. ones. i am afraid 19 hr injectors will cause me to run rich. can't i just boost the pressure with the regulator on the 17s and be ok. Viper, which do you have
Originally posted by NoRiceInside:
</font><blockquote>quote:</font><hr />Originally posted by zbigdawg:
am running 19's in my 3.4 only .3 richer on my rteal time data system. keep in mind all the mods i.e. p&p, cam, & more displacement will lean the mixture so larger injecters might be a good thought. whats the part # on the regulator and is it adjustable. my speed shop guru says nobody makes 1 for the 3.4<b><a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six©</b></a><br /><a href=\"http://www.sounddomain.com/id/95batmobile\" target=\"_blank\">My \'95 Bird</a><br />I am not afraid of storms, for I am learning how to sail my ship.
by Need4CamaroThe panel under the HVAC controls where the button is supposed to be is completely missing when I bought the car so I dont know if this car had TCS or...3 weeks ago
by Need4CamaroI was wondering, are these cars DBC or DBW?
If swapping in an LS motor (lets ignore the rest of the complexity of the swap), what would be...4 weeks ago
