yeah i bought a used Rksport supercharger kit and just got some more money from christmas and wanted to know if these parts that i plan on buying are good enough for the forced induction
#130 comp cams valve springs
comp cams Hi tech push rods
also should i use the stock retainers and valve locks?
also do you guys think i could use the zzperformance gt cam it says it can take intercooled boost so would it work with the supercharger?
i also am pulling out the while motor to do a complete rebuild with a three angle valve job, put on pacesetter headers, porting and polishing,and adding ls1 valves
