No Start - Harmonic Balancer? - FirebirdV6.com/CamaroV6.com Message Board
  • No Start - Harmonic Balancer?
    I just did an engine swap, (blew out my bottom end, 3.4 - 3.4) Can someone tell me how far the harmonic balancer needs to be installed onto the crankshaft? I'm getting a no-start condion and i think that the sensor behind it isnt reading that the crank is moving and i'm not getting spark or something. Starter, fuel pump and computer are turning on fine. I even got oil pressure after cranking for like..... a min or so. Thanks to anyone who can help. :-p
    -- Mike
    1995 Blue Chevrolet Camaro <br />Dynomax Exhaust, Custom CAI w/K&N, Throttle Body Bypass, ACDelco Plugs/Accel 8mm Wires. Indiglo Gauges. BMR Stut Tower Brace, ASP underdrive pulleys, BF Goodrich g-Force T/A KDW\'s around. <br />AIM: STMIKEK
    The short answer - all the way...
    put an impact on the bolt and drive it down as far as it goes (lube the seal first) - do not torque it on with the impact, just get it almost seated.
    RAR II
      theres a keyway on the crank so theres really no way to put the balancer on in the wrong position. as far as the crank position sensor goes, if its disconnected ur car WILL NOT start, no chance otherwise. if the sensor was damaged and does not work properly now, ur car WILL NOT start. im not sure about the 3.4, but i konw u dont have to on the 3.8, but on some cars u have to set the air gap on the sensor. MY CPS went bad and the car wouldnt start when it got hot, it would cut off, ran like *** . they can **** ur world up if they go bad. this is what ur ignition system gets it feed on start from and during running. so this caused a no spark condition on my car.
      also, dont crank the car over for long periods of time. anything more than 15 secs and u risk overheating the starter
      matt
      [ December 11, 2003: Message edited by: camaro97 ]</p>
      -Matt<br />Manager/Tech Support<br />Precision Speed & High Performance<br /><br />visit us on the web at:<br /><a href=\"http://www.precisionspeedonline.net\" target=\"_blank\">www.precisionspeedonline.net</a>
