How much lift is possible? - FirebirdV6.com/CamaroV6.com Message Board
  • How much lift is possible?
    How much lift can you run on the 3.8 before you have to worry about valve to piston clearance?
    Depends on the duration.
    At .520 lift you start to press on the valve seals if you did not mill the pedastals.
    Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
      so with a lift of .528, you would advise on getting the heads milled? .02?
      - \"So you have something to look at when you\'re talking to \'em\" - <br /> <a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=296916\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=296916</a>
        .528 should be ok..
        PEDASTALS.. not the heads.. the valve pedastals is where the valve seal sits on.
          right...
            Hmm. I'd think it'd be over .520". My cam at .528 doesn't cause this to my knowledge, and I say this only because my car doesn't have any sort of oil consumption issues.
              darn that is lousy for you guys...
              our V6 Ford stuff can endure .650"
              and stil have the .050" minimum
              covered easily. Chevy valvetrain
              is usually pretty good in most areas.
                RGR, thats the thing it isn't a Chevy motor its a Buick, these motors don't even adhere to the normal chevy bolt patterns.
                3.42 gears w/ LSD,<br />Headers, Cat delete, Loudmouth,<br />SLP intake, K&N, Whisper Lid, <br />EGR delete
                  i know about milling the pedestals and they will be when i port my heads but i wanna know before valve to piston clearance problems, thanks!
                    duration and lift are.... ??????
                    I've heard of guys running 224 duration with .605 lift
                      ill probably run around 212-216 @.050 and I want to run atleast .560 lift and maybe more if the heads will flow more...ill know more what cam i have after i port the heads and do some playing around on the flow bench...
                      [ December 11, 2003: Message edited by: WickEdSix9838 ]</p>
